[ANSYS Meshing] Meshing an airfoil with thickness (span) |
Rep Power: 9 ![]() |
I am trying to mesh an airfoil with span or depth, but i don't know what is the appropriate method to do that, all the tutorials on youtube are for airfoils with zero thickness or with zero depth or span. I have tried several techniques to mesh it but every time i end up with a skewness ratio 0.85-0.99 which is very bad and unacceptable. I have tried the following techniques: 1) sizing the airfoil edges and inflating the geometry ( selecting the two faces of the geometry as the "Geometry" and the edges of the airfoil as the "Boundary". 2) sizing the airfoil edges and inflating the geometry ( selecting the whole body as the "Geometry" and the inner faces of the airfoil (inside it) as the "Boundary". 3) I have also tried the use "Method" as tetrahedrons with patch confirming method and patch independent,, when using the it as patch independent, i get a skewness of 0.73 but when i add inflation the skewness blows up to 0.99 Geometry: [IMG] ![]() [IMG] ![]() [IMG] ![]() Meshing: [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
Amin
Rep Power: 14 ![]() |
let's divide you're problem into two parts,
first meshing the surface , second meshing the extruded faces (in z-direction), which is possible to do using insert>method>sweep and now you gotta only deal with meshing the face (your xy plane), which is exactly same as the plenty of tutorials available online |
#3 | |
Regards. |
#4 | |
do you have any other ideas ? |
#5 | |
Amin
well, let's focus on the sweep operator, what does the sweep do? it simply takes the nodes on a face (which could be either defined by the user or detected automatically) and uses them as a pattern and copies them along the path. That means you just need to mesh the desired surface and let the sweep take care of the 3D domain. Therefore, if you had to earlier choose a body and a face for inflation, now you only gotta select the face and edge. remember, first we only deal with the face meshing. so it's totally obvious that the user cannot simultaneously use a 3D inflation and sweep about the second problem, I guess it's due to the wrong setup which is in contrary to sweep. Are you only using the "mapped face" for ONE aforementioned face? check the attached |
#6 | |
Amin
There’s a point in ANSYS Meshing which I wonder why we have
to deal with this restriction, [we cannot use an inflation with “mapped face”], I don’t know the reason. Therfore you have to pick one of ‘em. I personally prefer to use mapped face and use a separate thin block near to the wall with a very small value of cells height for modelling the wall effect About the skewness, yeah, that’s a potential problem in meshing flow around airfoils, it depends on the airfoil type, though. You most likely gotta use sub-blocks to have a good mesh, especially if your airfoil is not symmetric, just look it up online, there are so many tutorials online on how to mesh a 2D airfoil, after that u just need to use sweep for extruding the nodes in normal direction |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
[snappyHexMesh] Meshing NACA airFoil with snappy | Paolo.F | OpenFOAM Meshing & Mesh Conversion | 6 | October 8, 2013 04:52 |
[GAMBIT] Meshing airfoil using .dat file problem | creggie | ANSYS Meshing & Geometry | 10 | June 27, 2010 19:24 |
Help regarding basic airfoil meshing in CFX | amoolraina | ANSYS Meshing & Geometry | 2 | May 22, 2010 18:51 |
