blocking strategy in ICEM CFD
Like Tree1Likes
  • 1 Post By JBeilke
Old   February 28, 2018, 05:42
Default blocking strategy in ICEM CFD
karthikeyan
rsskarthikeyan is on a distinguished road
I want to validate the 2D airfoil Wind tunnel results with CFD solver. I tried in many ways, Could not get proper results.
The various research paper suggests " O grid gives much better results than C and H mesh blocking strategy.
Kindly give some suggestion on how to make O grid around the airfoil as given in http://blog.gridpro.com/the-art-and-...hing-airfoils/
rsskarthikeyan is offline   Reply With Quote
Old   February 28, 2018, 10:21
Joern Beilke
JBeilke is on a distinguished road
A simple O-grid topology should be no problem in ICEM Hexa. For the last example with nesting I would probably try to import a GridPro mesh into ICEM and extract the topology from there.
Years ago I solved the problem of flexible topology creation by throwing ICEM out of the window and using GridPro instead :-)
rsskarthikeyan likes this.
JBeilke is offline   Reply With Quote
Old   March 7, 2018, 06:29
karthikeyan
Is it possible to access this tool as free version without any limitations?
Old   March 7, 2018, 06:39
Joern Beilke
The academic version is limited to 100 blocks, which is nearly nothing for real world cases.
Just contact the people from GridPro directly. The developement team is located in India.
Old   March 9, 2018, 04:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
wow. I like gridpro very much. But mostly use ICEM CFD for various reasons.
Far is offline   Reply With Quote
aspect ratio, blocking strategy, icem 14.0, mesh 2d
[ICEM] ICEM Blocking and Meshing - Flow over Periodic Hill Crank-Shaft ANSYS Meshing & Geometry 8 April 29, 2014 04:11
How to create boundary layer using ICEM cfd and using blocking meshing strategy costy Main CFD Forum 0 April 12, 2014 05:14
Learn ANSYS ICEM CFD easy_astronaut ANSYS 2 December 15, 2013 16:34
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 01:51
Overall Strategy for use of CFD in Design bstern Autodesk Simulation CFD 5 May 18, 2010 16:20
