[GAMBIT] Meshing problem on a simple curved geometry (Gambit Software)
Like Tree1Likes
  • 1 Post By -mAx-
Old   February 18, 2018, 05:49
Default Meshing problem on a simple curved geometry (Gambit Software)
Parham Vatankhah
Parham Vatankhah is on a distinguished road
I am trying to mesh a semi-circle volume on gambit software. The problem occurs when I try to mesh the outer and inner surface. (Please refer to the picture) Any suggestions?
Thanks in advance
Parham Vatankhah is offline   Reply With Quote
Old   February 18, 2018, 12:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
max is the most appropriate person to contact on this matter...
https://www.cfd-online.com/Forums/members/-max-.html
Far is offline   Reply With Quote
Old   February 19, 2018, 02:16
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Try to split your surface as follow
It may help
Parham Vatankhah likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 19, 2018, 04:02
Parham Vatankhah
Thank you for your prompt response. I have found the problem. The problem occurs since it was not a semi-circle. The initiating part was a cube that was followed by a semi-circular geometry.
Splitting the cubic part of the volume solves the problem.
[ICEM] Building geometry meshing problem Yatharth Vaishnani ANSYS Meshing & Geometry 1 June 12, 2016 07:33
[ANSYS Meshing] Problem in geometry meshing Itachi11 ANSYS Meshing & Geometry 3 March 15, 2016 15:38
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 21, 2006 00:31
Cooling simple 3D geometry problem Luk FLUENT 4 May 12, 2006 10:47
