February 8, 2018, 20:11 |
Merge Two Meshes
joygiak
Rep Power: 9 |
Hello Guys,
I am working on a mesh for a propeller, inside of a rectangular duct . I have already make the structured mesh for the propeller as you can see in the first picture. Also for the duct I made a structured mesh, as you can see in the second picture. The common face is the green area. I am trying to merge these two domains in a proper way. The final result would be like something, third picture. I want the air flow to pass through the blue inlet circle and the red inlet area to be a wall! After this, I would solve the case in CFX! Can anyone suggest me a way to do it right ; Any advice would be useful , thanks in advance! |
February 9, 2018, 07:46 |
Follow this
#2 | |
Follow these steps. 1)Save the first mesh (propeller) as a seperate project (eg. project1). Name it's outer boundary as eg. Interface_1 before you save it. (make sure you convert to unstructured mesh before saving it) 2) Save the second mesh(outer mesh) as a seperate project (eg. project2). Name it's inner boundary (the one that will merge with interface_1 with a new name (eg. Interafce_2). (make sure you convert to unstructured mesh before saving it) 3)Now create a new project (eg. project3). Open the geometry of project1 and then open the geometry of project2. 4)when you open the geometry of project 2 you will be given an option to replace or merge geometries. choose merge. 5)Now open the unstructured mesh for project 1 followed by the unstructured mesh for project 2 and choose merge as well. And then bam, you have your desired mesh. Thanks MS |
November 7, 2018, 23:40 |
Problems with merging geometry
Fonas Juhrmeister
Hey @sheerez234
I tried to do what you described here, but I have a problem in merging geometry. When I load the second geometry and click merge, the two geometries never merge on interface, but on another wall. Although I have defined all my geometry.. do you know any possible mistakes I made? |
November 8, 2018, 07:44 |
Gert-Jan
Rep Power: 28 |
Why do you want to merge these?
In CFX, you can import both meshes separately and define a sliding interface between the rotating and the stationary part, not? Then both volumes will be treated as separated meshes, so there is no need to merge. Not even in a frozen rotor simulation...... |
November 8, 2018, 11:23 |
Fonas Juhrmeister
hey Gert-Jan
thanks for your answer, but i am not the guy who originally post this thread. i try to mesh a transacted rotor with smallblades. so i have one geometry with mesh which is 10mm wide and another with different kind of blades, which is 90mm wide. i need to merge them on an interface surface, but they always merge on the outer wall of 10mm wide geometry, so i got an overlapping meah |
July 8, 2020, 03:31 |
Sai Krishna
Rep Power: 8 |
Hi Shereez,
I have a doubt regarding this. If we open 2 geometries and perform merging, will the 2 interfaces created get merged or we need to merge them manually. I am working on a geometry consisting 2 cylinders with 2 different blocking setups. so meshed them separately and tried to merge the meshes as you suggested. But its not happening. The 2 surfaces remained as it is and my structured mesh changed to unstructured. I have attached screenshots for the reference and any help will be appreciated. Thanks Screenshot (235).jpg Screenshot (236).jpg |
icem, merge meshes, propeller |
[ICEM] Merge volume meshes Hexa-tetra with ICEM | ConteGhibel | ANSYS Meshing & Geometry | 6 | April 20, 2018 07:00 |
Merge Meshes in parallel | DominicTNC | OpenFOAM | 0 | September 4, 2017 23:39 |
[mesh manipulation] Best way to merge meshes? | Tensian | OpenFOAM Meshing & Mesh Conversion | 0 | November 27, 2016 08:07 |
[ICEM] Smoothing before merge meshes | FJSJ | ANSYS Meshing & Geometry | 0 | May 20, 2013 12:30 |
Merge 2 unstructured meshes | vinc | ANSYS Meshing & Geometry | 0 | May 19, 2011 17:14 |
