October 23, 2017, 04:10 |
Stop the meshing procedure
Dim. G
Rep Power: 9 |
Hey everyboy,
In some cases when I am meshing a geometry, I may give very small element size and thus the meshing computational time is too large, so is there a way to "break - stop " the creation of the mesh? To be more specific, in matlab if you want to break your code while running you have to press "ctrl + c ", so is there an equivalent shortcut for ansys meshing? Thank you in advance |
October 23, 2017, 09:42 |
Stuart
Rep Power: 26 |
Click Stop on the ANSYS Workbench Mesh Status dialog box.
October 23, 2017, 09:45 |
Dim. G
Rep Power: 9 |
apparently it doesn't do the job. Whenever I press stop the process doesn't stop and I have to close the software from task manager. Maybe there is something wrong with my pc, but I have tried it to many other computers and I think they have the same problem
October 23, 2017, 10:23 |
Stuart
Rep Power: 26 |
I know I've had to wait quite a while when I need a stop a large mesh during its generation.
October 25, 2017, 04:20 |
Rep Power: 14 |
Only quick way i know of is killing the "Ansys Meshing Server" in Task Manager. It will stop meshing immediatly.
what is the procedure for applying dynamic meshing | rsaurabh | FLUENT | 6 | July 23, 2016 17:52 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Meshing strategy for External Flows | Hybrid | ANSYS Meshing & Geometry | 0 | January 24, 2012 14:27 |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
