[ANSYS Meshing] Baffle (zero thickness) wall
Like Tree3Likes
  • 1 Post By sina_mech
  • 1 Post By vasava
  • 1 Post By Antanas
Old   September 6, 2017, 13:49
Exclamation Baffle (zero thickness) wall
SinaJ
sina_mech is on a distinguished road
How can I create a zero thickness wall in Design Modeler (ANSYS Geometry)? and how can I mesh it using ANSYS Meshing tool?
I can create a surface in DesignModeler but when I import it to Meshing tool, I cannot figure to mesh it properly as a zero thickness wall (or baffle).
Thank you
andelsaev likes this.
sina_mech is offline   Reply With Quote
Old   September 7, 2017, 17:31
SinaJ
Any suggestion?
Old   September 8, 2017, 16:05
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I can tell you about the ICEM CFD.
Far is offline   Reply With Quote
Old   September 8, 2017, 16:10
SinaJ
Thanks for your reply. I can do it in ICEM, but couldn't figure it in ANSYS Meshing.
Old   September 11, 2017, 06:13
Paritosh Vasava
vasava will become famous soon enough
Have you tried using shared topology in DM? The use of baffles is possible with SpaceClaim using following steps (from Ansys Portal), you can look for corresponding setup in DM.
1. Define your solid and surface elements.
2. Combine/Put these parts to one component.
3. Set the property "Share Topology" of your geometry which includes the baffles to "Merge".
sina_mech likes this.
vasava is offline   Reply With Quote
Old   July 14, 2022, 02:58
Antanas is on a distinguished road
The topic is old, but I post guidelines for DM and Meshing for those who still wondering:
1. Model your zero thickness walls as surface bodies that lie inside your fluid body.
2. Combine 'em via multibody part.
That's all. Ansys Meshing will respect 'em during mesh generation (works only with Tetrahedrons and MultiZone methods).
All relevant information is in documentation, search for "baffle meshing".
NHeidfeld likes this.
Antanas is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
How to add Fluent Wall thickness option in OpenFoam? dappe OpenFOAM Running, Solving & CFD 8 November 18, 2015 14:07
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
boiler with a thickness of the wall cecillia FLUENT 1 May 27, 2008 22:14
first wall layer thickness and droplet size itchie CFX 3 May 14, 2008 10:03
