[ICEM] Refinement and Mirroring
Like Tree1Likes
  • 1 Post By Far
Old   September 4, 2017, 16:11
Default Refinement and Mirroring
Andy
Starcatcher is on a distinguished road
I have here a very interesting problem, which I would like to solve:
I built up an very simple mesh with perfect cell quality. Only two blocks (generated by splitting).
For one block I used the "refinement" function . ("blocking"->"pre-mesh params"->"refenement") (see figure 1)
After that I mirrored the generated mesh (without the blocking) with activated options “copy” and “merge nodes”. (see figure 2) As recommended I deleted the redundant upper surface shells with were inside the volume after mirroring.
When reading the mesh in fluent, the following error appears:
“Cell is missing face: Cell 1858, zone 9, at location ( 2.53906e+00, 1.04167e+00, 6.90234e-01).
Clearing partially read grid.
Error: Build Grid: Aborted due to critical error.
I looked for the coordinates given in the error notification by generating a point at this place. It was the first corner-cell after the refinement. (see figure 3)
What to do? Where can be the Problem?
Important: Reading refined mesh without the mirroring works as well as reading a mirrored mesh without refinement. IT’S THE COMBINATION, that makes problems?
Isn’t that interesting? Would be glad about some hints.
Thanks
Starcatcher is offline   Reply With Quote
Old   September 6, 2017, 04:27
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
post tin and blocking file here.
Far is offline   Reply With Quote
Old   September 6, 2017, 09:06
Andy
the upload window here does not accept these file types, so i hat to put it in a zip file.
temp.zip
Old   September 6, 2017, 12:37
Far
Sijal
file received. come back to you as soon as possible
Starcatcher likes this.
combination, mirror, refenement
