[ANSYS Meshing] sweep meshing issue ansys 18.0 |
August 21, 2017, 06:15 |
Cees Haringa
Dear all,
For some reason, Sweep meshing in ansys 18.0 is not working out for me. It's consistently giving me a tetrahedral mesh, in cases where full hexahedral sweep meshing worked just fine in earlier versions of ANSYS. Did anyone else run into this issue? And are there any solutions? Best, Cees |
August 22, 2017, 06:26 |
Stuart
Rep Power: 26 |
Are you certain the body is sweepable? Right-click in the Meshing Tree to show all sweepable bodies and see if it is highlighted. For instance, there could be an unexpected vertex on a edge which needs fixing. I've used the sweep method countless times in R18.
August 22, 2017, 07:19 |
Cees Haringa
It certainly is; I have now reverted to v15 (which was still installed on my workstation) to do the meshing, and there's absolutely no issues there.
August 24, 2017, 03:26 |
Matthias Voß
Rep Power: 20 |
Did you set the sweep algorithm by hand? I am asking since you are saying that you get a Tet-mesh every time. Otherwise get in contact with your Software dist. and report a bug.
Sent from my iPhone using CFD Online Forum mobile app |
August 24, 2017, 03:36 |
Cees Haringa
yes, I pretty much tried out every option there...
So oddly noone else seems to have this issue? |
August 24, 2017, 08:52 |
Stuart
Rep Power: 26 |
Maybe you can upload the geometry to see if other get the issue.
August 24, 2017, 12:40 |
Cees Haringa
The specific geometry is proprietary, but it isn't a geometry dependent problem. It also happens when I make a simple ring-cut geometry. So let's say:
1: make a cylinder (r = 1, h = 1) 2: cut out a second cylinder (r = 0.5, h = 1) to create a ring 3: slice in half, and suppress one half. In previous versions, I could very easily sweep the mesh around the axis (and combined with size control on the edges, make very neat hex meshes). In 18.0, this doesn't happen. It mostly makes tets, and if it does make hex, it's not swept but hex-dominant (and poorer in quality) |
August 25, 2017, 05:51 |
Stuart
Rep Power: 26 |
I just followed your instructions and by default ANSYS Meshing made a swept mesh. This was all in ANSYS R18.2.
August 25, 2017, 09:05 |
#9 |
Cees Haringa
Nice and curvy, that's how I like my meshes. I'm currently working on some simulations (with my wonderful ansys 15 mesh), but I'll see if I can make a few shots of what it looks like for me afterwards in the standard geometry. Mine are 18.0 though, we are yet to update.
[ANSYS Meshing] Script for Ansys meshing | Riadh | ANSYS Meshing & Geometry | 11 | January 9, 2019 18:06 |
[ANSYS Meshing] Hexa mesh with Ansys Meshing possible? | olegmang | ANSYS Meshing & Geometry | 0 | July 24, 2015 12:25 |
[ICEM] ANSYS Meshing & ICEM with one license | vasava | ANSYS Meshing & Geometry | 0 | March 20, 2015 09:13 |
[ANSYS Meshing] Ansys meshing with extended meshing | jsm | ANSYS Meshing & Geometry | 6 | January 10, 2011 13:09 |
