[ICEM] Missing face critical error while importing icem mesh to fluent |
July 13, 2017, 05:59 |
tuhin
Hello everyone,
I'm trying to mesh a 2d transonic airfoil using icem cfd blocking and converting pre mesh to unstructured-mesh. After conversion while checking the mesh in edit mesh menu it only shows me warning of single edge elements around the boundary which, I learned from this discussion forum, can be ignored. But when I'm trying to import the mesh in ansys fluent it shows me the following critical error: > Reading "C:\Users\admin\Desktop\polynomial_cascade_files\d p0\ICM\ICEMCFD\ICM.msh"... 19944 nodes, binary. 19542 quadrilateral cells, zone 10, binary. 38508 2D interior faces, zone 11, binary. 99 2D wall faces, zone 12, binary. 99 2D wall faces, zone 13, binary. 39 2D wall faces, zone 14, binary. 39 2D wall faces, zone 15, binary. Warning: Invalid face type 1. Skipping. Building... mesh WARNING: Cell 0 of thread 10 is missing face 2. Clearing partially read grid. Error: Build Grid: Aborted due to critical error. Error: Build Grid: Aborted due to critical error. Error Object: #f The mesh is loading fine in ansys-cfx. I searched through the internet about the error but did not find any satisfactory solution. This study is actually a part of my summer project and I need to finish it positively in next few days. Hence any quick help will be highly appreciated. Thanks |
March 10, 2018, 17:25 |
Bota Amdrei
Rep Power: 11 |
Did you solve this problem ? I am receiving the same while importing the mesh from ICEM to Fluent
March 12, 2018, 09:17 |
#4 | |
Gert-Jan
Rep Power: 28 |
1. export from ICEM to CFX5-format 2. import into CFX-Pre 3. write a def.file 4. import the def.file into Fluent. Porbably you can skip step 1 by importing the exported .msh-file (from ICEM to fluent) directly into CFX-Pre. |
March 12, 2018, 09:20 |
Bota Amdrei
Rep Power: 11 |
Thank you for your advices
fluent 15.0, icem cfd 15.0, missing face |
[ICEM] error while importing mesh to FLUENT from ICEM | @nuj | ANSYS Meshing & Geometry | 0 | April 13, 2016 08:41 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
