May 28, 2017, 09:37 |
ICEM-Extrude mesh by rotation
Sagar More
Rep Power: 12 |
I am trying to extrude 2d mesh with rotation in ICEM. I want top surface of extruded mesh to be rotated by 15 degrees with respect to original 2d elements and 5 mm away (translated) from it. I have used spacing 0.5,angle per layer 1.5 and no. of layers 10. But I could not get rotation angle of 15 degrees. I have also tried using angle in radians in angle per layer tab. Angle of rotation depends on spacing also. Please explain how it works. |
May 29, 2017, 08:59 |
D. N. Venturi
Rep Power: 13 |
I've never done it. But maybe you can extrude the block without any rotation. And then, rotate the end points of the block.
April 1, 2021, 19:38 |
#3 | |
Gang Wang
Rep Power: 8 |
I'd like to know have you solved this issue? I'm also strugging with this problem for quite a long time. Best regards, Gang Wang |
extrude mesh, icem 15, mesh rotation |
[ICEM] Extrude 2D mesh, face names to volume names, line names to face names | baloe | ANSYS Meshing & Geometry | 0 | January 6, 2017 18:39 |
[ICEM] extrude surface mesh for solid wall | Daniel_Khazaei | ANSYS Meshing & Geometry | 13 | May 29, 2014 10:25 |
ICEM CFD 5.0 - 2D to 3D Mesh Extrude | James Date | CFX | 7 | October 22, 2013 04:46 |
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts | a.habibi | ANSYS Meshing & Geometry | 5 | October 4, 2012 06:10 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
