[ICEM] Negative grid occured at boundary layer |
April 5, 2017, 13:29 |
LintaoZhong
Rep Power: 9 |
Hi guys
In order to realize y+<1, 2e-6mm first boundary layer height has been set in ICEM using structure grid. But once spacing is less than 3e-4mm I set, negative grid will be occurred. And most strangely, the negative grid occurred at inlet and outlet all the time. No matter how I adjust spacing but increasing spacing more than 3e-4mm. It has perplexed me the whole day. Sincerely Lintao |
April 5, 2017, 21:51 |
Rep Power: 24 |
Your mesh size might interfere with your geometric tolerance. Try lowering the value for tri tolerance under model/units.
April 9, 2017, 08:52 |
#3 | |
April 23, 2017, 06:20 |
LintaoZhong
Rep Power: 9 |
icem, structured grid |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 14:47 |
