[ANSYS Meshing] Why do close parallel lines always become crossed when transfer to Ansys Meshing |
January 20, 2017, 15:40 |
gao
I am simulating Fuel cell, the thickness of catalyst layer is only 0.01mm, which can be set up successfully in DesignModeler, but when the geometry is transfered into Ansys Meshing in Workbench, the two parallel lines of one face of the catalyst layer become crossed, and the face is destroyed, moreover, it will be OK if the two lines distance is more than 0.02mm. Could someone tell me how to do to simulate 0.01mm catalyst layer smoothly?Thanks!
[ANSYS Meshing] Script for Ansys meshing | Riadh | ANSYS Meshing & Geometry | 11 | January 9, 2019 17:06 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Can you help me with a problem in ansys static structural solver? | sourabh.porwal | Structural Mechanics | 0 | March 27, 2016 17:07 |
mass transfer in ANSYS | thipps | ANSYS | 1 | August 29, 2013 11:05 |
Strange ANSYS Meshing 13.0 Problem | brunob | ANSYS Meshing & Geometry | 3 | June 21, 2011 20:03 |
