[ICEM] Surface does not follow curves, ICEM
Like Tree1Likes
  • 1 Post By yonpanman
Old   January 5, 2017, 16:01
Default Surface does not follow curves, ICEM
Johannes Hall
yonpanman is on a distinguished road
Hello everyone!
I have imported point data for a 3D wing in ICEM. It works well but when create curves from the point, they don't really follow the points. I suspect this has to do with the number of points that might need to be increased.
The real problem, however, is when I generate surfaces from the curves. The surfaces do not follow the curves. This creates errors in the geometry when I later generate the mesh and unfortunately, these errors are large enough to affect the flow. So I would like to get rid of them.
I have tried to reduce the tolerance, but the problem still remains. I should also mention that I have the "show full" option for the surfaces so unfortunately it's not a graphical thing.
My question is if anyone has an idea of how to solve this? Is the problem in the curves or the surfaces? As I said before, the curves does not follow the points correctly neither so I'm not really sure.
Any help is much appreciated! I'll attach some pictures so you have an idea of what I'm talking about.
Regards
yonpanman is offline   Reply With Quote
Old   January 6, 2017, 06:29
Johannes Hall
I found a solution:
In settings, go into model/units and change the triangulation tolerance. This made the surface follow the curve much better.
mehran.mo likes this.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Problem with surface mapping using mesh from ICEM and CFX solution eliass ANSYS 0 April 14, 2015 05:24
ICEM Surface problem error404 ANSYS Meshing & Geometry 6 June 6, 2014 05:33
[ICEM] ICEM surface trim and blocking projection Felipe Mendes ANSYS Meshing & Geometry 3 May 21, 2012 04:08
ICEM Surface from points cloud ? Guillaume CFX 1 June 13, 2007 15:42
