[ICEM] How to get a good C mesh over a NACA 0012
Like Tree3Likes
  • 3 Post By shereez234
Old   December 20, 2016, 16:11
Default How to get a good C mesh over a NACA 0012
aero_cfd is on a distinguished road
I am trying to get a good quality C mesh for naca0012 but so far I don't get good aspect ratio and orthogonality .
I used same steps as in this tutorial,
https://www.youtube.com/watch?v=OhNz9OhaCRc
I do want a denser mesh and possibly use it for RANS or DES .
Any tips on how to proceed to good very high quality ?
Thank you
aero_cfd is offline   Reply With Quote
Old   December 23, 2016, 08:32
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Originally Posted by aero_cfd View Post
Thank you
Maintaining orthogonality is more difficult for sharp trailing edges. However, you could follow these tips.
1 - Use a symmetrical blocking.
2 - Use more nodes on regions of importance.( i.e. Along length of Airfoil and downstream).
3 - Make sure you have a smooth cell size change.
4 - In the farField ( outlet, Inlet, walls) use copy edge parameters - ( copy to selected edges) and then increase the spacing here. So that the very thin cell spacing close to the airfoil is not carried out to the farfield cells ( this will improve aspect ratio and orthogonality).
shereez234 is offline   Reply With Quote
airfoil, icem, mesh
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
