Lenzo
Rep Power: 12 ![]() |
Hello once again!
I have already read some posts about it, but I think that my case is slightly different. I have the geometry attached, which is composed by different parts assembled. My fluid will go through the hole inside. Thus, I have to mesh the hole. Usually, what you mesh is the geometry on itself. I have found videos about add frozen geometry and all that jazz https://www.youtube.com/watch?v=Bb8Tsd9eGe4 But i don't want to surround my geometry with a mesh, but to fill the gap inside my geometry. Thank you for any support |
#2 | |
Rep Power: 18 ![]() |
[snappyHexMesh] meshing the geometry of an heat exchanger | RobSie | OpenFOAM Meshing & Mesh Conversion | 0 | November 30, 2016 10:22 |
[ICEM] Building geometry meshing problem | Yatharth Vaishnani | ANSYS Meshing & Geometry | 1 | June 12, 2016 06:33 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ICEM] Meshing on a Complicated Geometry | tav98f | ANSYS Meshing & Geometry | 2 | August 17, 2011 11:15 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
