[ICEM] How to draw a 2D surface to a solid 3D Body |
Bowen Li
Rep Power: 9 ![]() |
Hi everbody,
I'm a beginner at ICEM. I want to know how to draw a surface to a solid body. I want to draw the surface (red part in the first Picture) to a solid body. First I copied the surface in z direction and sweeped all the curves through two points. The result please have a look at second picture. But I found that, it generate only surfaces not a closed solid body. And when I prepare to make a mesh with "curve mesh" on the entities, it occurs problem. Can any body help me to solve this prblem? I am thankful for any hint. If there's any uncertainties, please ask. Thank you! Greetings |
Gwenael H.
Rep Power: 20 ![]() |
Hello Bowen,
The best way is to directly import the “solid” part you want to mesh in ICEM. If for some reasons you want to sweep the existing curves within ICEM you should create a body in ICEM selecting 2 mat points within your “solid” domain. Have fun ![]() |
Bowen Li
Hallo Gwenael,
First I appreciate for your respnding. That's right I must finish the Geometry in ICEM. I tried to creat the body through selecting surfaces (please see first picture), but some error happend (please see picture 2). Is that mean I have to add all the things like curves or points in part "GEOM" to the part "ISOLATOR" ? Thanks for your help! |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[DesignModeler] Question about converting surface body to solid body in DesignModeler | lnk | ANSYS Meshing & Geometry | 2 | November 24, 2013 00:02 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
