[ANSYS Meshing] Setting up translational periodic region
Like Tree1Likes
  • 1 Post By oozcan
Old   October 12, 2016, 07:12
Question Setting up translational periodic region
Ţórólfur Björn Einarss
Thorolfur is on a distinguished road
Hi
I have finite long pipe with dense small holes through the wall, equally distributed, and I just want to simulate the fluid flow for a small segment of it that represents a periodic part. you can see part of the geometry in attachment.
I can not find any information on this forum about how to createtranslationally periodic region in ansys workbench design modeler/meshing.
I´ve been trying to use the cyclic one as a reference, described here; http://www.cfd-online.com/Forums/flu...-tutorial.html, and modified to translational but doesn´t work because I can´t seem to be able to define the coordinate system (yellow highlight doesn´t disappear).
I would be much obliged if someone could point me to the right direction or post me a link that gives step-by-step description
Best regards
Ţórólfur
Thorolfur is offline   Reply With Quote
Old   December 2, 2016, 06:12
Default Setting up translational periodic region
Gabriel Rojas
gabrojas is on a distinguished road
Hi Thorolfur,
did you figure out how to set up the periodic region? I have exactly the same problem as you, the coordinate system is not accepted. Ansys Help has no page on how to create symmetries in Meshing.
If you, or somebody else, could share your solution, that would be of great help.
Thx,
Gabriel
gabrojas is offline   Reply With Quote
Old   December 2, 2016, 07:11
Onur Özcan
oozcan is on a distinguished road
Originally Posted by Thorolfur View Post
Hi
Best regards
Ţórólfur
I think that it has been relevant to FLUENT but ANSYS-Meshing has not
oozcan is offline   Reply With Quote
Old   December 2, 2016, 07:15
Onur Özcan
there are two ways periodicity that are translational and rotational.
It could be done by selecting correct boundary conditions with TUI command.
please check it : http://www.engr.uconn.edu/~barbertj/...heat/tut02.pdf
if you still have a problem following reading the tutorial, we can talk about that issue again.
Kind Regards,
Onur Özcan
gabrojas likes this.
ansys meshing, periodic bc, periodic region, pipe flow
[ICEM] Setting Periodic Boundary Conditions Arjun87 ANSYS Meshing & Geometry 15 March 14, 2017 04:34
Setting Boundary Conditions for stl geometry (periodic cooling fin tunnel) gelbebanane OpenFOAM Pre-Processing 3 December 6, 2013 14:56
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 18:46
how to provide translational periodic faces ib Open Foam sachinlb OpenFOAM 0 October 28, 2011 05:36
Setting turbulent plane poiseuille model to periodic boundary conditions. QBeast FLUENT 0 July 17, 2011 11:08
