[ICEM] align vertices tool
Like Tree1Likes
  • 1 Post By bluebase
Old   September 2, 2016, 09:34
Default align vertices tool
jumpmonkey is on a distinguished road
Hi everyone,
I cannot figure out how the 'align vertices' tool works. ( found under blocking=>move vertices => align vertices)
I have attached a picture to use as an example. the picture shows two views of the same thing.
i want to move the 'blue vertices' so that they lie on the plane formed by the 'black edges'.
is this the type of situation that this tool is for? If not.. what tool do i use? and what situation does the align vertices tool apply to?
thanks
jumpmonkey is offline   Reply With Quote
Old   September 5, 2016, 09:20
Sebastian Engel
bluebase will become famous soon enough
Hi JumpMonkey,
i haven't fully figured out myself how to use 'Align Vertices', too. Though, i know this tool moves vertices within a given plane. So, only XY, XZ, ... or given plane. If your geometry is distorted in the 3d space, then it seems tricky to use this tool.
In your case i would suggest to use 'Align Vertices in-line'. With this tool the reference vertices represent a straight line where selected vertices are to be moved to.
Select the two boundary vertices ('black') of the same block cut as reference vertices. Then select the internal vertices ('blue') of the same block cut. Repeat this for all cuts.
With regards,
Sebastian
jumpmonkey likes this.
bluebase is offline   Reply With Quote
Old   September 12, 2016, 10:37
Hi Sebastian,
Thank you for replying! The align vertices in-line tool worked well
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
Tool to download: SU2 post-processing Combas SU2 2 June 5, 2014 15:55
[ICEM] Specifying Periodic Vertices Causes Mesh Overlap Josh ANSYS Meshing & Geometry 10 July 8, 2010 03:39
[blockMesh] Tool Block generation with blender wikstrom OpenFOAM Meshing & Mesh Conversion 8 August 12, 2009 18:09
Icem CFD 10: Align vertices of splitted edges Michele CFX 2 March 11, 2006 11:07
