[DesignModeler] Reference Geometry in Sketch?
Like Tree2Likes
  • 2 Post By shivasluzz
Old   August 1, 2016, 21:42
Default Reference Geometry in Sketch?
James Wright
u2berggeist is on a distinguished road
I have been searching for a way to reference geometry in a sketch inside DesignModeler. For example, say I have a vertex on a shape at an arbitrary point (aka, I don't know the exact coordinates) and I want a line in a sketch to start on that vertex.
Normally I just define everything and use parameters to make points be in the same place, but I've gotten kind of fed up with spending 3 minutes on a task that takes me less than a second to do in all the other CAD software I deal with.
Is there a way to do this? Making references to geometry seems like a pretty dumb thing to not have, but ANSYS have made more interesting decisions in the past, so it wouldn't surprise me.
u2berggeist is offline   Reply With Quote
Old   August 2, 2016, 15:41
sluzzer
shivasluzz is on a distinguished road
1. Create New Plane
2. Right click and Insert 'Sketch projection'
3. Select the feature which you want to use as reference in 'Sketch projection' and generate
TurbinePower and voidcrow like this.
shivasluzz is offline   Reply With Quote
Old   August 2, 2016, 15:46
James Wright
Thanks! That was exactly what I was looking for.
designmodeler, reference geometry, sketch design modeler
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
Error in compiling new drag model k.farnagh OpenFOAM Programming & Development 13 May 21, 2016 04:08
OpenFOAM 1.6-ext git installation on Ubuntu 11.10 x64 Attesz OpenFOAM Installation 45 January 13, 2012 13:38
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
