[ICEM] generate a curve or surface in the axi-symmetric geometry with ICEM
Like Tree5Likes
  • 5 Post By bluebase
Old   June 2, 2016, 09:44
Question generate a curve or surface in the axi-symmetric geometry with ICEM
openfoammaofnepo is on a distinguished road
Dear All,
I would like to generate a curve and then rotate this curve to generate a surface with ICEM. I know the function of this curve but I do not know where I can input this function in ICEM. My geometry is axis-symmetric. Does anybody know how to do this with ICEM?
Thank you in advance !
OFFO
openfoammaofnepo is offline   Reply With Quote
Old   June 3, 2016, 09:13
Paurnamie Samarakone
Nat Sam is on a distinguished road
Hi
So you know how to draw a curve right ? What you don't know is how to generate a surface that rotates ?
You need a curve and an axis around which this curve would rotate to generate the surface
Geometry -> Create / Modify Surface -> Surface of Revolution
Nat
Nat Sam is offline   Reply With Quote
Old   June 3, 2016, 09:19
hi Nat,
thank you. my question is about how to generate a curve based on a known function, like a power function. do you know how to do this ?
The function is as follows:
r(x)=-18*x^3 + 6.4*x^2 + 0.1, where x is the streamwise coordinate.
Originally Posted by Nat Sam View Post
Hi
Nat
Old   June 3, 2016, 09:39
Oh sorry I didn't uderstand that at all. Thought I was helping you x)
I'm afraid I do not know how to do that on ICEM. If you know how to use a CAD software like CATIA, I suggest you draw you geometry using that. That's what I did (currently doing an internship using ICEM)...
Hope someone can help you soon !
Nat
Old   June 3, 2016, 09:52
Thank you all the same!
Nat
Old   June 6, 2016, 14:36
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
i don think you can use function in ICEM CFD. You can use excel to get coordinates and take them to ICEM CFD. Then revolve it in ICEM CFD to get surface.
Far is offline   Reply With Quote
Old   June 7, 2016, 07:10
No. We can generate the point with the functions and then connect these point to generate the curves. It can work.
Old   June 7, 2016, 08:44
Sebastian Engel
bluebase will become famous soon enough
Well... do you know how or not...?
Do you know about the replay function of icem? Yes? Then you should also know, that icem scripts are in tcl language. Have a look at some tutorials on that language in case you never heard of tcl.
To give you an idea how to do it, i have prepared a short script for you. i guess, it is already more than i should help! Save it into a text file with *.tcl ending and run it with icem.
With regards,
Sebastian
(Little 'homework'... try to figure out how to connect all those points with a script)
set steps 100.
set xmin 0.0
set xmax 0.1
set crvlgh [expr $xmax-$xmin]
set steplgh [expr $crvlgh/$steps ]
for {set n 0} {$n <= $steps } {incr n} {
  set xvalue [expr $n*$steplgh + $xmin]
  set functionvalue [expr -18.*pow($xvalue,3.) + 6.4*pow($xvalue,2.) + 0.1]
  ic_point {} PARTNAME pointname.$n "$xvalue,$functionvalue,0"
Last edited by bluebase; June 10, 2016 at 08:44. Reason: Corrected little error in coordinates calculation
bluebase is offline   Reply With Quote
Old   June 10, 2016, 08:44
Sebastian Engel
There was an error in my calculation. I edited it. Now it should work flawlessly.
Old   June 11, 2016, 01:42
Far
Sijal
Excellent work.....
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 19:48
[ICEM] STL Geometry in ICEM asal ANSYS Meshing & Geometry 3 February 5, 2013 10:44
[ICEM] Forcing surface and curve to match sherifkadry ANSYS Meshing & Geometry 0 August 27, 2010 01:28
flow over an airfoil 3d ( Geometry on icem cfd ) dfmona Main CFD Forum 0 April 14, 2010 00:32
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 03:49
