[ANSYS Meshing] Problem with High Skewness Mesh
Like Tree1Likes
  • 1 Post By Kapi
Old   May 31, 2016, 22:56
Default Problem with High Skewness Mesh
CFD2016 is on a distinguished road
Hi everyone,
I am meshing for the container ship which is located in the wind tunnel.
The problem is the meshes long the intersection between the stern and bottom wall have high skewness (>0.9).
I have tried to use sizing function and mesh sizing (body, face, edge),however, the problem could not be solved.
Attached is the mesh elements with high skewness.
Please help me!
Thank a lot!
Best!!
CFD2016 is offline   Reply With Quote
Old   June 1, 2016, 01:28
Kapi is on a distinguished road
did you use "HARD" behaviour in Sizing function?
CFD2016 likes this.
Kapi is offline   Reply With Quote
Old   June 1, 2016, 03:15
Hi Kapi,
Thank you very much for your quick reply.
I have tried both "Soft" and "Hard" behaviour in sizing function. However, there are some remained high skewness elements.
What could I do?
Old   June 1, 2016, 19:34
mate, use Edge sizing with hard behavior and reduce your element size and it will solve the problem!
Old   June 1, 2016, 21:26
I reduced the element size half, even 1/10, but the problem could not be solve.
Old   June 2, 2016, 11:26
Could you give me your email address? I want to discuss more detail about my problem.
Thanks!
Old   June 3, 2016, 02:18
Please discuss whatever you want to discuss! its beneficial for others having similar problem. Reduce your element size in that area by 1000 and run it. See what the problem is!
If you dont have any edge thr then use sphere of influence!
Old   June 3, 2016, 02:43
There is an edge between Hull and bottom wall as you can see in the image.
I had tried to use body and sphere of influence but there was no improvement.
Now I will try with smaller edge elements size as your suggestion.
Thanks!
Old   June 3, 2016, 03:17
I reduced edge elements size to 0.0001m (Lpp=1.5m). I supposed this is small enough, however, the number of high skweness cells has increased. May be the large cells were divided into many smaller cells.
Pls take a look at the photo.
Old   June 7, 2016, 20:16
umm!!
try Bias type with small parts towards end and bigger parts away from that area and give bias factor of 10 and see how it looks. Reduce the bias factor if required!
Old   June 7, 2016, 22:41
umm!!
I have tried to use bias factor (10-5-2-1.2) with the element size 0.0001~0.001.
However, it could not be solved.
Do you have any idea?
Do you think the problem may come from the geometry, the angle between the hull (stern) and the bottom surface? If so, how to fix this issue?
When I used patch independent, the maximum skewness < 0.9 (around 0.88). But the mesh is very coarse.
It does not success with other meshing methods like Hexa or Cut cell etc.
Attached is the details of mesh which I am using.
The length of ship model is 1.5m.
Total number of elements is approximate 5million for patch independent and 3.7million for patch conforming.
Even I tried to reduce the min and max size, It still could not be solved yet.
Thank you!
Old   June 7, 2016, 23:38
you dont have to use full model of ship.
use symmetry and reduce your mode size.
I dont see this as geometry problem but i have never done ship modelling, so I will leave it expert who has done ship modelling.
Search the website for similar topics and you mite be able to get some answer!
Old   June 8, 2016, 02:28
I am going to calculate the wind resistance acting on the ship, the wind direction changes in case (0~180deg). That is why I use the full model.
Any way, thank you so much for taking your time and discussing.
Best regards,
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
High Skewness in Hexcore Mesh/ Tgrid xaero Main CFD Forum 4 November 10, 2009 12:04
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
