[ANSYS Meshing] Guidelines for inflation layers |
May 18, 2016, 05:27 |
Euan
Rep Power: 10 |
Hi
I am interested in any guidelines people may have for using inflation layers. I understand the first cell height for the correct Y+ value. Does anyone have any tips for things like - How many layers to use - How far the total height of the inflation layers should extend beyond the boundary, certain controls make the last cell in the inflation quite large, which may be a good thing if trying to match it to the surrounding mesh. - The face size on the boundary in comparison to the cell height, presumably if the face size is much larger than the first cell height then the cell will become distorted, or is the advantage of inflation layers that they can be much thinner in height compared to their width without losing quality. Thanks |
May 20, 2016, 05:59 |
Rep Power: 13 |
HTML Code:
http://www.computationalfluiddynamics.com.au/tips-tricks-inflation-layer-meshing-in-ansys/ HTML Code:
http://www.computationalfluiddynamics.com.au/tips-tricks-cfd-estimate-first-cell-height/ HTML Code:
http://www.computationalfluiddynamics.com.au/tips-tricks-turbulence-part-4-reviewing-how-well-you-have-resolved-the-boundary-layer/ |
May 27, 2016, 07:49 |
Euan
Rep Power: 10 |
Thanks I'll take a look!
boundary, layer, prism, wall, yplus |
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh | Rohith Giridhar | ANSYS Meshing & Geometry | 3 | June 29, 2015 17:52 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[Other] Meshing Layers over Aerofoil | poloding-along | OpenFOAM Meshing & Mesh Conversion | 5 | April 4, 2014 10:41 |
Fluent diverges when using inflation layers | ziggo | FLUENT | 4 | August 9, 2013 12:11 |
Layers and turbolence in Interfoam | danvica | OpenFOAM Running, Solving & CFD | 0 | April 30, 2012 03:11 |
