May 2, 2016, 04:29 |
Negative Volume
Aja
Rep Power: 15 |
Hi....
I dont know that why is created negative volume in the following Gambit file...I used Boundary layer in Gambit. I am grateful that guide me about this case. http://www.4shared.com/zip/VtOR6dREce/GGG.html Thanks. Best. Aja |
May 2, 2016, 07:52 |
Maxime Perelli
Rep Power: 41 |
Try to upload your file on another server (dropbox for instance), your link bring lot's of pop-up ( and I am at the office...)
In memory of my friend Hervé: CFD engineer & freerider |
May 2, 2016, 08:51 |
Aja
Rep Power: 15 |
https://www.dropbox.com/s/8n0ivbyf793jmqc/GGG.zip?dl=0
Max, I face with these problems(Negative volume messages) very much in Gambit. Sometimes i change ratio(I increase first element) and then there are negative volume messages in Gambit and it is ok. but sometimes i have to apply fine first element that then negative volumes messages appear. This is weakness in Gambit. How do i fixed this problem in Gambit? Thanks. |
May 2, 2016, 09:06 |
Maxime Perelli
Rep Power: 41 |
I cannot reach your file.
You need to place your file in Public folder, then copy and paste the link.
May 2, 2016, 10:33 |
Aja
Rep Power: 15 |
I am new in dropbox! i don't see public folder...
Please see the following link, Do you download it? http://s6.picofile.com/d/3dafde93-be...4cce2c/GGG.zip |
May 2, 2016, 10:45 |
Maxime Perelli
Rep Power: 41 |
now it is ok.
Check your mesh on faces 832 / 890 /85 /882; it is not ok. That's why you get negative cells
multiphase turbulance case floating error | harsha_kulkarni | OpenFOAM Running, Solving & CFD | 3 | February 18, 2016 06:06 |
[ICEM] negative sector volume | adam2008 | ANSYS Meshing & Geometry | 0 | August 9, 2014 01:24 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
remeshing due to negative volume error | Doginal | CFX | 1 | August 21, 2011 22:50 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
