[ANSYS Meshing] Icem generated mesh changing in cfx solver |
April 28, 2016, 21:09 |
Faizan
Rep Power: 12 |
Hi all,
I am facing problems in convergence for a steady state flow on CFX. I am simulating a supersonic flow using deLaval nozzle. I have three domains. 1. Surrounding air Fluid Domain. 2. Solid Nozzle domain and 3. High pressure Nitrogen Fluid Domain. I built the mesh on ICEM in an assembled form then I exported all three domains separately. I imported three domains in CFX and used GGI interface for wall connection for all three domains. It is surprising that CFX Solver changed the mesh quality which I built in ICEM. The ortho, aspect ratio and exp.factor values were changed by solver. The simulation is failing when at a point when high pressure nitrogen mixes with surrounding air. I am posting a pictures of existing mesh. Please suggest how can I overcome this mesh problem. I don't want to increase the mesh elements. I need guidance to increase the mesh quality for supersonic flow to achieve convergence. Any help/suggestion would be appreciated. thanks in advance, regards, Faizan |
April 28, 2016, 21:11 |
more pics attached
Faizan
Rep Power: 12 |
More pics attached
April 28, 2016, 21:12 |
more pics
Faizan
Rep Power: 12 |
more pics of mesh
April 29, 2016, 09:40 |
Dr. Flow Squad
Rep Power: 17 |
The mesh jumps to brute from one to the another.
May 1, 2016, 22:36 |
Faizan
Rep Power: 12 |
Hi Dr.Flow,
Yes- I agree with you. I am new to ICEM meshing. I used Bigeometric rule with 1.2 edge ratio. Now I would appreciate if you can assist me to develop a quality mesh for three domains without increasing mesh density. Any coarse mesh with high quality would be sufficient for my project because I need to expedite the convergence. Thanks Faizan. |
May 2, 2016, 04:35 |
Faizan
Rep Power: 12 |
Hi all,
Please advice/suggest me as what should I do to incerase the quality of mesh on icem. I am new to ICEM and do not know much option. I am using bigeomteric rule under edge parameter. I linked the spacing with 1.2. I once increased the no. of nodes but it only increased the solver time. No significant change. As I mentioned earlier that when I import the mesh in cfx using workbench. I used GGI interface option and cfx automatically oriented the nodes for two fluid domains and once solid domains. It is changing the mesh ortho, aspet ration but not the exp factor. I was on other forum and a gyu told me to go to icem forum to fix the expansion ratio issue. Please help...any expert opinion will be highly appreciated. Thanks |
May 2, 2016, 04:37 |
Faizan
Rep Power: 12 |
how to handle the expansion ration on ICEM???
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
[ANSYS Meshing] Question about ICEM mesh output to CFX | lnk | ANSYS Meshing & Geometry | 0 | July 27, 2012 16:39 |
CFX Wind turbine mesh trouble and solver failure | tallliam | CFX | 9 | April 29, 2012 23:55 |
Error when creating ICEM mesh output to CFX | Zoran | CFX | 4 | November 9, 2010 06:13 |
CFX mesh import from ICEM (Windows) | Andrew | CFX | 7 | July 6, 2006 12:39 |
