[GAMBIT] mesh generation and geometry creation packed bed reactors
Like Tree1Likes
  • 1 Post By -mAx-
Old   April 11, 2016, 09:38
Default mesh generation and geometry creation packed bed reactors
Manu Chakkingal
manuc is on a distinguished road
Hi
Could anyone share tutorials on how to create a packed bed reactor ( spheres arranged in a cylinder) and how to mesh the same.
Thanks
manuc is offline   Reply With Quote
Old   April 12, 2016, 03:01
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
*create your reactor without sphere
*create one sphere and place it on its right position (first level)
*create another sphere on same level by using copy tool
*create all aother spheres for same level with same technic.
*once the level is accomplished, create a group with all your spheres which belong to this level, and duplicate the level in the axial direction (x times).
*Once your geometry is ready you need to extract fluid domain with boolean tool
manuc likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 12, 2016, 03:04
Manu Chakkingal
Dear Max
Thank you for the update. But I read somewhere that placing the spheres one over the other touching each other would cause meshing issues..Or shoudl i place them untouched and arrange them in that case
Regards
Old   April 12, 2016, 03:09
-mAx-'s Avatar
Maxime Perelli
yes it will,
Just avoid placing spheres tangential each other
Old   April 12, 2016, 03:12
Manu Chakkingal
if I want to have some arrangement like HCP, then one layer has to be tangential to other right.
In that case should i give a small orientation of say 1 degree to that layer..Do you mean it to be so.
Old   April 12, 2016, 03:18
-mAx-'s Avatar
Maxime Perelli
don't know what HCP is.
i don't know exactly what you want to do, but I can only confirm, that tangential spheres will generate error while meshing.
I would try to mesh your reator with only 2 spheres tangential.
You will see the issue.
There is also a tool in Gambit for cleaning sharp angle.
You may try it, maybe it will fix the issue. But you need to do it, once you fluid domain is extracted, because the result of cleaning tool generate virtual geomtry.
And boolean operation (for extracting fluid domain) only work with real geometry.
Old   April 12, 2016, 03:24
Manu Chakkingal
Thank you I will take care of it.. the arrangement that I was talking of is attached herewith
(https://www.google.nl/search?q=packe...wjZ2ZTrD6JM%3A).
In the document containing this images its mentioned to be meshed in gambit.
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[snappyHexMesh] snappyHexMesh - geometry does not appear in Mesh czhongrong OpenFOAM Meshing & Mesh Conversion 1 January 20, 2016 06:26
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
