[ICEM] Sharp leading and trailing edge airfoil |
March 16, 2016, 08:19 |
Robert Jack
Rep Power: 10 |
Hello there,
I'm trying to mesh a symmetric airfoil with a sharp leading and trailing edge (see pic for the geometry), however I didn't manage get the software ICEM to mesh it properly (see other picture). I've tried to import only the top half of the geometry and mesh it, and them I mirrored the geometry and blocks but the lower part doesn't take into account the airfoil geometry. I've also tried to mesh the full airfoil at once, but every I end up with this sort of results. Any ideas ? Thanks Last edited by matters_100; March 16, 2016 at 08:21. Reason: added the images |
March 16, 2016, 09:04 |
Nader Khattabi
Rep Power: 10 |
try this tutorial it helped me a lot
https://www.youtube.com/watch?v=NVyvEH-u0wQ |
March 16, 2016, 09:35 |
Robert Jack
Rep Power: 10 |
Thank but the problem comes from the sharp leading edge of the airfoil. Hence, the topology of the mesh should not be a C-mesh nor a O-mesh.
Any other ideas ? Thanks. |
March 16, 2016, 13:44 |
Nader Khattabi
Rep Power: 10 |
try this one then
https://www.youtube.com/watch?v=mgjRT4WY_iA |
March 17, 2016, 09:37 |
There are two approaches.
First approach. 1. Make four splits . Two at leading and trailing edge. Two at upper and lower surface of airfoil. 2. Make fifth (vertical) split at mid chord. 3. Merge blockes at leading and training edge 4. associate edges and vertices. Set pre mesh parameters and you are done. |
March 17, 2016, 10:06 |
Stuart
Rep Power: 26 |
This is also similar to the ICEM CFD tutorial: Hexa Mesh Generation for a Pipe with Embedded Blade, see the ICEM CFD Tutorial Manual.
March 17, 2016, 10:59 |
March 17, 2016, 11:03 |
#8 | |
Robert Jack
Rep Power: 10 |
SOLVED.
Thank you everyone, I was missing a step as given in Far's answer: Quote:
and that's why it failed before. Last edited by matters_100; March 17, 2016 at 11:15. Reason: tried to clarify the post |
March 17, 2016, 11:12 |
#10 |
Robert Jack
Rep Power: 10 |
I suppose my response wasn't clear :/ but it's solved.
Thks |
April 5, 2016, 15:20 |
second approach
#11 |
Rep Power: 11 |
Hi Far,
what about the second approach? |
sharp leading edge |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 14:53 |
Leading edge and trailing edge of an airfoil rotor blade | Jun_Milan | CFX | 0 | July 11, 2014 00:07 |
[GAMBIT] meshing trailing airfoil | carp | ANSYS Meshing & Geometry | 4 | March 20, 2013 02:12 |
Y-Plus values at aerofoil leading edge and trailing edge at high incidence | Engr07 | Main CFD Forum | 4 | June 29, 2012 11:42 |
[DesignModeler] Creating a blunt trailing edge from collapsed leading edge | gmd | ANSYS Meshing & Geometry | 0 | March 2, 2012 10:48 |
