[ICEM] How do I create a transition from structured to unstructured mesh?
Like Tree4Likes
  • 1 Post By Andrea1984
  • 3 Post By niablis
Old   February 18, 2016, 18:50
Default How do I create a transition from structured to unstructured mesh?
B.H.
niablis is on a distinguished road
I am creating a structured mesh to model the boundary layer around a plane, but then I would like the mesh to transition to unstructured at a certain distance. I have not been able to find any good tutorials or discussions on this problem in a 3-D mesh. Any suggestions or help would be much appreciated!!
niablis is offline   Reply With Quote
Old   February 21, 2016, 19:39
Andrea
Andrea1984 is on a distinguished road
If the unstructured mesh that you want to use it's a full tetra mesh, the solution is straightforward: generate the structured and the unstructured mesh separately, load them at the same time (using the merge option when prompted), and then merge the two meshes at the interface (pyramids will be created as transitional elements between hexa and tetra).
If your unstructured mesh contains inflation layers, then it is a bit more complicated...
niablis likes this.
Andrea1984 is offline   Reply With Quote
Old   February 22, 2016, 14:50
B.H.
Andrea,
Thanks for your reply! I will test out your method today and get back to you if I have any questions.
Cheers!
Old   February 23, 2016, 14:16
B.H.
To wrap up this thread, and to help others that may have the same question I did, I found the best solution in the ICEM 15.0 tutorial manual under "Merged Tetra-Hexa Mesh in a Hybrid Tube". The key was that the structured mesh was saved in its pre-mesh state in blocking and then loaded back in after the unstructured mesh had been generated.
Far, granzer and Dronzer like this.
unstructured mesh phoenics user Phoenics 26 March 22, 2012 13:17
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
