[ICEM] meshing-incomplete mesh in part after moving blocks to separate domains |
November 23, 2015, 20:40 |
Faizan
Rep Power: 12 |
Hi all,
I am trying to move blocks and relevant mesh to respective parts. But I have a problem that I am unable to generate a complete mesh for any of the part. For example, when I moved the nozzle blocks to nozzle part and create the mesh elements, it appeared to be like the image attached. I was unable to generate the complete mesh shape of nozzle, even though the blocks are present. When I moved the block of HPGAS and created the mesh elements. It was incomplete And for AIR geometry, a portion of nozzle was absent as per attached image. Would anybody suggest as where am I making mistake? Am I selecting the wrong blocks or is any mistake in associated of edges? As per my understanding if I separate the blocks and generate the mesh, then mesh should have a complete shape of the geometry. Is it because of coarse mesh? Please suggest. Your guidance will be much appreciated. Regards, Faizan |
November 25, 2015, 04:24 |
Gwenael H.
Rep Power: 20 |
Hi Faizan,
This looks like an association problem to me. It is recommended not to mix geometry and blocking elements within the same part, so you should create a specific part for your nozzle blocking. Depending on how you associate your vertices/edges/faces, sometimes when you "move" the blocks to a new part the associations can go wrong. The first thing to do is to check the associations, you can update them under Blocking tab > Associate > Update Association (6th icon) > check Vertices, Edges, Faces > Apply If it didn't fix your problem you need to re-associate your edges/faces and recompute the premesh. Have a nice day |
November 25, 2015, 21:08 |
Mesh-Lines problems
Faizan
Rep Power: 12 |
Hi Gweher,
Many thanks for your response. I have managed to separate block in one part, then I created a separate topology for desired part and generated the mesh. It works fine with me as long as mesh export is concerned. But I have another problem just aroused that when I brought the mesh in CFX-Post and sliced all domains from center to visualize the connectivity of nodes and mesh lines. I found some abnormal mesh lines and corrupted nodes. I am unable to understand why is had happened because before mesh export from ICEM I checked the mesh QUALITY and it was excellent. I am attaching the pics. Please suggest. Thanks in advance. |
November 26, 2015, 02:45 |
Gwenael H.
Rep Power: 20 |
Hi Faizan,
Happy that it solved your problem. Regarding the export can you describe your procedure ? |
November 26, 2015, 03:24 |
Faizan
Rep Power: 12 |
Hi Gweher,
In ICEM, I converted the mesh to unstructured. Then in Output menu I chose ANSYS CFX solver and wrote the input file for CFX mesh exported with extension .cfx5. Pl. suggest. Faizan |
November 26, 2015, 04:29 |
Gwenael H.
Rep Power: 20 |
That's correct, I would add the boundary conditions before exporting. Do you mind sharing your .tin and .blk files ?
November 26, 2015, 20:08 |
Faizan
Rep Power: 12 |
Hi Gweher,
Thanks for your response. Actually I am always confused about the boundary conditions. In fact I wish to ask you about it like as where and which software should I put those boundary conditions. I mean should I put boundary conditions in ICEM? or Should I declare boundary conditions in ANSYS CFX-Pre? which method is suotable and preferable. As you know in CFX-Pre, you can choose boundar conditions by selecting correct faces of your mesh regions. Please suggest. I tried attaching .tin and .blk files but it is giving me security error. Pl. suggest your email id so that I can forward you my project files. Thanks in advance, Faizan |
November 27, 2015, 08:46 |
Gwenael H.
Rep Power: 20 |
Hi Faizan,
It's easier to assign the boundary conditions within ICEM. Even if you want to change their type in CFX-Pre. For the .tin and .blk I've send you a private message. |
November 29, 2015, 21:11 |
#9 |
Faizan
Rep Power: 12 |
Thanks Gweher- I have sent you the files on email you provided.
Look forward to hear from you, Faizan |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[mesh manipulation] Combining multiple mesh blocks | ingojahn | OpenFOAM Meshing & Mesh Conversion | 1 | August 18, 2014 03:19 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
