[ANSYS Meshing] Creating mesh suitable for translational periodicity |
November 12, 2015, 17:56 |
Hi there,
I'm unable to create a mesh, using ANSYS Meshing, suitable for translational periodicity, on FLUENT. I guess I've read something about the periodic faces must be conformal, so that's why I need to set this periodic region on meshing (right?!). How do I do it? I just wanna simulate the flow over this airfoil (s809; chord = 150mm). The dimensions of the volume of air are 1050mmx300mmx10mm. I know It's not correct to define this side walls as 'symmetry' for 3D simulations, so I'm trying to apply periodicity in the spanwise direction (and it's not working so far...) ps.: I know this is not the volume indicated for this kind of simulation, but that's what I can solve with my notebook. Can anyone help me?? Thx |
November 24, 2015, 17:42 |
Nikola
Rep Power: 12 |
Hi AJE,
This is out of my (sleepy) head cause I don't have access to ANSYS at home. Try using matching controls on the faces together with symmetry>periodic>translational periodic. You must create cartesian coordinate system for this on one periodic face and in translational periodic menu for offset use distance between faces (watch out whether it is plus or minus sign). In Fluent, you can assign interface BC to the faces you want to be periodic and then in Mesh Interface tab set them to be periodic and use the right offset value. (BTW, meshes don't have to be conformal on faces for periodic to work. But conformal should be more accurate.) |
March 13, 2016, 14:21 |
#3 | |
vlg
Rep Power: 18 |
periodic boundary |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 08:59 |
[ICEM] creating a mesh with interfaces | sk692 | ANSYS Meshing & Geometry | 0 | January 12, 2015 14:23 |
[ICEM] 2D mesh extrusion and periodicity | robboflea | ANSYS Meshing & Geometry | 1 | August 31, 2013 16:34 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
