[ANSYS Meshing] Application error in CFX-Pre
Like Tree1Likes
  • 1 Post By shivasluzz
Old   October 8, 2015, 11:13
Default Application error in CFX-Pre
Laszlo is on a distinguished road
I am getting the following error message when I try to start CFX Setup (CFX-Pre):
"The file from which the mesh is to be imported does not exist. "
"Unable to import the requested mesh"
I saved my project in Mesh. In the Workbench/File panel it shows there is a CFX.mshdb in folder ....dp0/CFX/MECH
Even when I try to export and then import into CFX-Pre does not work.
Can anyone help?
Thank you!
Laszlo is offline   Reply With Quote
Old   October 9, 2015, 09:13
sluzzer
shivasluzz is on a distinguished road
Try importing the mesh file in the standalone cfxpre.. Not through workbench
shivasluzz is offline   Reply With Quote
Old   October 9, 2015, 10:45
Thank you for the answer!
How can I do it?
(I tried to export the mesh in .cgns and then import it into CFX-Pre but it still stops with error message.)
Old   October 9, 2015, 11:01
sluzzer
In the workbench, there is a component 'FE modeler'... In the workbench, transfer your mesh from ansys meshing to FE modeler... From FE modeler, export outside to cfx pre supportable format... Close the workbench... Open Cfx-pre seperatly and import that mesh..
Old   October 9, 2015, 18:05
I tried. The mesh is exported, CFX-Pre started outside of the workbench, mesh then I tried to import it into CFX-pre. But there is a warning message: "The selected file does not exist. Please choose a new file."
But the file does exist. It is there with .fedb extension and 241664 bytes...
What am I doing wrong?
+ what is more "funny" that whatever file I choose the message is the same...
Old   October 11, 2015, 14:28
P_VS is on a distinguished road
Originally Posted by Laszlo View Post
Can anyone help?
Thank you!
I have the same problem when importing a mesh in CFX-Pre.
Have you already found a solution?
Thank you!
P_VS is offline   Reply With Quote
Old   October 11, 2015, 17:33
no....... And my work is standing still......
Old   October 12, 2015, 02:44
sluzzer
I used to get this problem sometimes... But it got solved wen I imported in standalone cfx-pre..
Also very first after installing the software I got this problem.. That was solved by by giving the administrative rights to the workbench default folder.. I mean u may not have the full rights to the folder where the workbench reads and writes.. Check that and tell me
P_VS likes this.
Old   October 12, 2015, 13:45
Thank you so much!! It was actually more complicated than that: the folder where I was saving my projects wasn't inside the ANSYS Inc folder. So I moved it there and, as you said, chaged the ANSYS folder's administrative rights and included my user. Finally, I allowed the user to write in the folder.
And that's it.
Once again: Thank you
Old   October 13, 2015, 00:58
sluzzer
Glad to hear that ur problem is solved :-)
Old   October 13, 2015, 17:40
I have the same problem. I changed the rights and removed any write protection from the folder and subfolders...
cfx-pre
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 17:50
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
Create a virtual Surface into a domain in CFX PRE chuck209 Main CFD Forum 0 August 13, 2012 13:10
Defining a domain in CFX Pre ashtonJ CFX 1 June 13, 2011 03:34
CFX Pre Hide symmetry symbols alvid CFX 2 August 15, 2007 12:34
