[ICEM] 3d blocking for hexa meshing a cylinder
Like Tree1Likes
  • 1 Post By CFD_Aspirator
Old   September 14, 2015, 00:47
Question 3d blocking for hexa meshing a cylinder
Vishnu
CFD_Aspirator is on a distinguished road
Hai all,
I have a 3d cylinderical geometry to be meshed. It is of radius 0.5 m and height 1m. All the surfaces are wall BC's. The top flat surface has an inlet of radius 0.05m. The inlet is offset from the centre, so I can not use 2d axisymmetric assumption. So I have to do a 3d meshing. I am unable to understand in what way I can do the associations. Please help me.
abdi mohamed likes this.
CFD_Aspirator is offline   Reply With Quote
Old   September 15, 2015, 03:32
Maxim
-Maxim- is on a distinguished road
you should check out the tutorials. Especially the ones with Ogrids. It sounds like you want to mesh a standard cylinder - that should be pretty easy with an Ogrid.
If not, please post pictures so that we can understand your problem better.
-Maxim- is offline   Reply With Quote
associations, blocking, cylinder domain, icemcfd
[ANSYS Meshing] Meshing 3d circular cylinder in ICEM darazsbence ANSYS Meshing & Geometry 0 March 11, 2014 17:35
[ANSYS Meshing] Regarding 3-D meshing of hollow cylinder Thermal_engg ANSYS Meshing & Geometry 11 July 6, 2013 01:22
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp Crank-Shaft ANSYS Meshing & Geometry 0 January 11, 2013 06:48
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 4 October 19, 2010 17:45
