[ICEM] Delete block, keep mesh shape
Like Tree1Likes
  • 1 Post By FJSJ
Old   September 2, 2015, 14:11
Default Delete block, keep mesh shape
Jose
Lanzagorta is on a distinguished road
Hi all
I am meshing a domain with a cylinder in the middle. The cylinder has a small height so it does not reach the limits of the domain (see picture).
I can generate the mesh the way I want it before deleting the blocks inside the cylinder. See pictures. The 3D mesh is formed of a repetition of the section show in the image "mesh_section".
The plan will be now to delete the 5 blocks that "are inside the cylinder". In the picture "mesh_section_detail", blocks 30, 42, 45, 41, 46. The problem is that when I delete this 5 blocks, weird associations appear and the mesh gets terrible (see pictures).
The message continues below.
Lanzagorta is offline   Reply With Quote
Old   September 2, 2015, 14:12
Default Continuation
Jose
Even when I correct the associations the mesh is still terrible close to the cylinder.
However, in both cases, the mesh still remains correct in the lower and upper boundaries of the domain.
What I really don't understand is that the associations are the same in the upper and lower boundaries as in the cylinder, why is not the mesh the same?
Find also the project in ICEM in case someone wants to have a closer look.
Mesh_ICEM.zip
Thank you very much for your help!
I really appreciate it
Lanzagorta
Old   September 3, 2015, 10:28
Default Summary of the question
Jose
I am going to summarize the question in this post, because maybe it was too long previously.
I have a 3d domain with a cylinder in the middle and I want to analyse the flow around the cylinder. The cylinder is of limit height so it does not reach the boundaries of the domain. I can achieve a mesh exactly as I want it, but covering the whole domain including the cylinder. So, I just need to delete the blocks inside the cylinder, without modifying the mesh outside the cylinder.
Does someone know how to do it?
Please help
Old   September 3, 2015, 11:06
Javi
FJSJ is on a distinguished road
Hi Lanzagorta,
Does the cylinder have covers? In case you have covers...Did you associate cover surfaces with block faces?
Lanzagorta likes this.
FJSJ is offline   Reply With Quote
Old   September 3, 2015, 14:40
Jose
Hi FJSJ,
The cylinder did not have covers that was my problem. Thank you for your help
Old   September 3, 2015, 19:28
Attique Javaid
attiquejavaid08 is on a distinguished road
Please help
let me know if this was something you were looking for.
Geometry and Blocking Files:
https://drive.google.com/file/d/0B4Y...ew?usp=sharing
attiquejavaid08 is offline   Reply With Quote
cylinder, delete block
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[blockMesh] Mixer mesh - negative volume problem jadtwo OpenFOAM Meshing & Mesh Conversion 2 November 6, 2014 17:37
[ICEM] Merge created block resulting in not connected mesh imamwfgf ANSYS Meshing & Geometry 2 October 20, 2013 07:22
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
