[Workbench] FSI Ramping error
Like Tree1Likes
  • 1 Post By krishna18
Old   September 1, 2015, 07:30
Angry FSI Ramping error
saikrishna
krishna18 is on a distinguished road
I am trying to simulate FSI I am facing the error.
System coupling run completed with errors. Transient Structural (Solution 1) reported: Preconditioned conjugate gradient solver error level 1. Possibly, the model is unconstrained or additional iterations may be needed. Try running setting the multiplier MULT on the EQSLV command to greater than 1.0 (but less than 3.0). Please do not save the project if you would like to recover to the last saved state.
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient supports. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
Abdulrajak Buradi likes this.
krishna18 is offline   Reply With Quote
Old   September 15, 2015, 12:05
stumpy is on a distinguished road
This means the structural solver diverged. Try running the structural-only case with representative pressure loads and make sure this solves OK.
stumpy is offline   Reply With Quote
fsi 2-way coupling, workbench
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
POSDAT problem piotka STAR-CD 4 June 12, 2009 09:43
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
