[Other] Fluent mesh: prism layer error
Like Tree4Likes
  • 2 Post By obscureed
  • 2 Post By Fabio88
Old   August 12, 2015, 06:28
Default Fluent mesh: prism layer error
Fabio Malizia
Fabio88 is on a distinguished road
Hi all,
I receive the following error when I try to create prisms in fluent mesh:
Prism Meshing is not supported for face zones of mesh objects
Below the procedure I applied in fluent meshing:
- Create geometry in cad
- import cad as mesh object and correct free nodes
- create size function for the surfaces of the body
- remesh it
- create boundary box using the construction size tool (as well as BOI, for which I un-ticked the option create object) and material point
- wrap my objects (not the box)
- group the 3 objects and the external box in one object called total
- when I go to auto mesh select the prism layer I want, fluent give me the error above.
I think it does not like that I meshed the faces, but it sounds strange for me that this cannot be possible, therefore I think I missed some steps in my workflow or I made some mistakes.
Thanks for any help you can provide me.
Fabio
Fabio88 is offline   Reply With Quote
Old   August 24, 2015, 09:52
Fabio Malizia
Sorry to update this thread but I still did not solve this problem.
Old   September 27, 2017, 06:17
obscureed is on a distinguished road
This might be too late for you, Fabio, but for the record:
I have seen the error in Fluent Meshing "Error: Prism Meshing is not supported for face zones of objects." -- but this was when I tried to add prisms to an existing volume mesh. This is a valid (and useful!) feature of Fluent Meshing, but for some reason it is incompatible with mesh objects. The answer here is to save a copy of the .msh (as always), then right-click on the object in the tree and delete the object *only* (keeping the faces etc). Then you can add prisms, morphing the existing mesh inwards.
As for the workflow that Fabio mentioned, where prisms are specified during volume-meshing in Automesh: it should work. (It helps if you have specified the boundary types of all face zones, so you can use the default scoping of prism layers on wall zones only.) It sounds possible that Fabio had created a mesh already, and then Fluent Meshing objected to adding prisms layers where there was already a mesh. In this case, the answer would be to delete the previous volume mesh (in Mesh...Manage) before Mesh...Automesh.
Fabio88 and CFDger like this.
obscureed is offline   Reply With Quote
Old   October 4, 2017, 06:36
Fabio Malizia
Hi Obscured,
never to late and thanks for your reply!
About my previous mesh error, I was not applying the prism layer to a volume mesh, but as you said, I was applying them to the faces of an object directly in the boundary layer mesh window (pushing the button create).
If I delete the object and create the boundary layer on the unreferenced faces, it works. Thanks!
What I previously did is:
- select the faces where I wanted to apply the bl in boundary layer mesh window and chose the settings
- push apply in the zone specific growth window
- push apply in the main window of the boundary layer window
- closed this window and push the button mesh in the automesh window
This workflow worked
Thanks again for your suggestion about the object deleting, I did not know this other procedure which indeed makes sense.
Cheers,
Fabio
CFDger and maxzhou like this.
Old   April 28, 2020, 07:18
Fabio Malizia
Quick update.
You receive this error also when you set (by mistake) two prism layers growing from the same face.
For example I have control-1 acting on all the walls of my domain and control-2 acting on the ground, which is also a wall face.
Then Fluent gives the error "is trying to reset settings applied on zones. Please fix this problem before proceeding". Just have only one prism layer growing from a face.
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 12:39
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
