[ANSYS Meshing] Expanding Mesh Size
Like Tree1Likes
  • 1 Post By hwet
Old   July 15, 2015, 17:45
Default Expanding Mesh Size
Sphagnum is on a distinguished road
Hi all,
Say that I have a 2d simulation with just a rectangle. I'd like to have the mesh be very fine near the bottom of the rectangle, and become increasingly larger as we move in the positive y direction. How is this done in fluent? The only thing I've found so far is the inflation method, but that isn't doing quite what I want- I ultimately need a triangular mesh and inflation always seems to force it to be rectangular.
Any and all input is much appreciated. Thanks!
Sphagnum is offline   Reply With Quote
Old   July 15, 2015, 19:17
hwet is on a distinguished road
Maybe trias with bias meshing, read the tutorials on this available on Ansys customer portal. i am sure i have read about doing this before.
Suzuki likes this.
hwet is offline   Reply With Quote
Old   July 15, 2015, 19:57
Kapi is on a distinguished road
Hi sphagnum,
As hwet suggested, giving Bias factor on vertical edges will make sure you have fine mesh at start and coarse mesh at top depending on which Bias type you choose.
I am not sure about fluent but in
"Ansys Meshing>Use Advance Size Function> On proximity and Curvature" helps in achieving the same result with Given growth rate(depends on your size of your geometry)
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   July 15, 2015, 21:29
Ahhh yes, I thought there was something I was forgetting from the tutorials I had done. Thank you very much for the help.
Old   July 16, 2015, 16:42
Hi all,
So I've been adding an edge sizing with bias factor, but that only expands the mesh close to the edge. Is there a way to change this so that it applies to the entirety of the rectangle?
Thanks again!
Old   July 16, 2015, 20:11
Give a higher "Bias Factor" and it will cover your whole geometry!
expand, inflation, mesh, size
[ICEM] Effect of globle mesh size and mesh independency sujay ANSYS Meshing & Geometry 20 September 29, 2019 08:36
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[ICEM] Holes in geometry appearing when surface mesh size decreases CCHunter ANSYS Meshing & Geometry 0 February 20, 2015 22:30
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 04:01
How to decide the mesh size? echo Siemens 1 May 23, 2006 06:34
