[GAMBIT] Dimensionless height of boundary layer thickness
Like Tree1Likes
  • 1 Post By -mAx-
Old   May 28, 2015, 08:11
Default Dimensionless height of boundary layer thickness
Aja
aja1345 is on a distinguished road
I designed a model of turbine. Now, I want to mesh this model.
Therefore, I should have a sufficient number of layers in boundary layer. But I dont know that what number consider. For this reason, I have to know value of Dimensionless height of boundary layer thickness until I can calculate value of thickness of boundary layer.
And also, I have to know value of growth factor for meshing.
I am grateful that guide me about these values and if it is possible, please place useful links about these subjects.
On the other hand, I want to use from K-e turbulence model with wall function.
Thanks,
Best,
Amir
aja1345 is offline   Reply With Quote
Old   May 28, 2015, 08:48
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can estimate BL thickness over a flat plate
http://en.wikipedia.org/wiki/Boundary-layer_thickness
you don't need to give exact values for you case, it is just a way to capture the BL with a fine and nice mesh. around your body.
Once you get converged solution you will see if your mesh around your body is good or not
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Boundary Layer roughness/ low reynolds wall treatment Luigi_ STAR-CCM+ 1 March 14, 2012 09:40
Boundary layer thickness ghazanfarzahedi Main CFD Forum 2 July 29, 2009 00:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
