[GAMBIT] optimum first cell height value for flow within a air turbine
Like Tree3Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   May 22, 2015, 09:19
Default optimum first cell height value for flow within a air turbine
Aja
aja1345 is on a distinguished road
Hi, I modeled an air turbine and I want to mesh a model of air turbine(Wells turbine). This turbine have 6 blades((360/6)=60 deg=angle between blades). Due to the circumferential symmetry, only one sixth of the annulus has been computed, imposing periodic boundary conditions in the tangential direction. The computational domain has been restricted in the axial direction to six chord lengths upstream and ten chord lengths downstream of the blade.
Also, the effects of separation, boundary layer interaction and vortex on the hub and surfaces of blade and Tip clearance are important in this modeling.
Now, I should obtain optimum first cell height value. The Reynolds number based on the blade chord was approximately equal to 2.4*10^5 that I found this Re number from a paper. I have some equations.
Firstly, I have a question that how to calculate this number for this model? Is this number calculated from relative velocity in this type of turbines? If so, How to calculate relative velocity for this model?
How to mesh on surfaces of blade and hub, casing and Tip clearance of turbine in Gambit? In other word, how do we know our acceptable Y+ value and inflation growth rate?
In fact, I want to obtain optimum first cell height values of hub, Casing and surfaces of blade. But How? I have to find optimum Y+ value, since the cost of a CFD evaluation obviously increases rapidly with the number of grid cells.
What do I the turbulence model use?
Could you please also tell me how to determine the boundary layer thickness on the surfaces of blade and hub and Casing?
I am grateful for guide me. Thanks for your help
Thanks,
Best,
Amir
aja1345 is offline   Reply With Quote
Old   May 22, 2015, 09:42
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
You have to check the theory for your Re
Regarding the y+ you have a online tool, for setting the first cell height:
http://www.cfd-online.com/Tools/yplus.php
In Gambit you also have a tool for meshing the BL. Gambit will create prismatic layers around your body.
Check Tutorial 13 from Gambit:
https://www.sharcnet.ca/Software/Gam...uide/tgtoc.htm
aja1345 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 22, 2015, 11:01
Aja
Hi max,
Thanks.
But this online tool is valid for flat plate. Is this tool also valid for turbo machinary?
Old   May 24, 2015, 02:50
Aja
NO one answer my question?
I really dont know that this online tool is valid for the turbo machinery, especially these type of turbines.
I am grateful that some one explain about this online tools. Do use this tool have many errors?
Old   May 26, 2015, 02:04
-mAx-'s Avatar
Maxime Perelli
This is an estimation.
Once you solution converged, you have to check your y+ to be sure your mesh is ok with your wall function.
If not then you need to adapt your mesh
aja1345 likes this.
Old   May 27, 2015, 05:03
Aja
Hi Max,
Ok, if I use wall function, I dont know range of Y+. Please guide me about this range.
Also, How to do this check in Fluent?
Thanks,
Best.
Amir
Old   May 27, 2015, 08:30
-mAx-'s Avatar
Maxime Perelli
please check the theory
http://www.cfd-online.com/Wiki/Intro...urbulent_flows
Then in fluent you have the possibility to display the contour of turbulence (Y+) or something like that.
aja1345 likes this.
How to setup simulation of injet Helium into Air cell zone? Shogan FLUENT 2 December 10, 2014 07:29
Reynolds number and 1st cell height Frank_M Main CFD Forum 0 June 12, 2013 08:10
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
air flow simulation in gas turbine enclosure Frankie FLUENT 2 December 28, 2001 23:54
design of centrifugal air turbine detchev Main CFD Forum 2 March 9, 2000 08:03
