[ANSYS Meshing] a problem in ansys meshing
Like Tree2Likes
  • 1 Post By FJSJ
  • 1 Post By Kapi
Old   May 14, 2015, 07:03
Lightbulb a problem in ansys meshing
M S
divoone1985 is on a distinguished road
hello.
the image i attached shows my problem.
how can i mesh the middle part as the top and bottom parts?
i define number of divisions for edges. but it didn't mesh correct.
plz help me.
divoone1985 is offline   Reply With Quote
Old   May 14, 2015, 07:15
Javi
FJSJ is on a distinguished road
You should make other splits (or "slices" in DesignModeler) on the top and bottom edges of your rectangle, and therefore, you'll have 5 different vertical edges. Then you chan especify the number of elements in each of them and remesh to get something as you got already on top and bottom parts
Instead of using sweep method I would use multizone quad/tri and "all quad" as free face mesh type.
divoone1985 likes this.
FJSJ is offline   Reply With Quote
Old   May 16, 2015, 16:11
Lightbulb
M S
how can i do that?
making slices.
Old   May 17, 2015, 19:48
Kapi is on a distinguished road
Hi divoone1985,
In designModeler(DM) top ribon you will find "Create>Slice"
Create new Plane where you want slices or select edge you want to slice and you have your 5 different parts.
Cheers
KAPI
Kapi is offline   Reply With Quote
ansys, mesh
Mesh difference between 14.5 version and 15.0 version in ansys meshing sunxihui ANSYS Meshing & Geometry 0 May 6, 2014 05:22
[ANSYS Meshing] Problem with ANSYS Meshing - how to refine? pyroknife ANSYS Meshing & Geometry 2 August 22, 2013 14:30
[ICEM] Meshing problem in Formula one Far ANSYS Meshing & Geometry 113 April 23, 2013 13:36
[ANSYS Meshing] Meshing Problem in worbench elina ANSYS Meshing & Geometry 0 March 31, 2013 09:53
[Other] Ansys meshing airfoil and / or compressor blades baw192 ANSYS Meshing & Geometry 8 September 23, 2011 01:43
