[ICEM] Cell Wall Distance, Quality Imprvement
Like Tree1Likes
  • 1 Post By shereez234
Old   April 12, 2015, 08:28
Question Cell Wall Distance, Quality Imprvement
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Fellow ICEM CFD users;
Here I have a hexa mesh of an Aircraft. When I checked it the quality is above 0.1 in ICEM. Then I converted it into an unstructured mesh from pre-mesh And the mesh size is 8 million elements ( 1.4Gb size Fluent mesh).
I took it to fluent and it says the mesh has a very low orthogonal quality ( different from ICEM). And I get an error saying " the cell wall distance is 1e-12 and repair the mesh).
However, my y+ is lower than 1 ( 0.000032m) and I do not know how to solve this problem.
Can some one advice me? And converting pre-mesh to unstructured mesh is the right way right? or is there a way to convert it into a multi-block mesh? because I thought Fuent just accepts unstructured meshes.
See the attached pics. Thanks a lot
shereez234 is offline   Reply With Quote
Old   April 12, 2015, 08:31
shereez234's Avatar
M Sereez
Old   April 12, 2015, 08:33
shereez234's Avatar
M Sereez
Sorry having a hard time attaching the pics spamming my own thread lol
Old   April 13, 2015, 05:57
Simon Harbeke
Hoyskipoyski is on a distinguished road
If Fluent computes on the mesh it seems the right way.
Although i'm not too familiar with blocking and structured meshs, i think to make the first cell bigger, go to your blocking and check the relevant spacings. After that make sure to recompute your pre-mesh and convert it again.
Hoyskipoyski is offline   Reply With Quote
Old   April 15, 2015, 23:47
shereez234's Avatar
M Sereez
Just for the benefit of other users..
I found the solution to this problem I think. It was because of my surface mesh having high aspect ratio elements. But increasing the surface mesh elements would mean a significant increase in the volume mesh as well. And luckily with information I found from another post here in the forum I came to knew that double precision solver of fluent can accept higher aspect ratios along the boundary layer and over all as well.
Hope this helps any one else who is facing this problem.
aero_head likes this.
structured hex mesh
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Journal file error magicalmarshmallow FLUENT 3 April 4, 2014 13:25
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
cell to wall distance azmir Siemens 0 March 27, 2007 02:03
