[ICEM] whats wrong with this mesh?(pic attached)
Like Tree7Likes
  • 1 Post By shereez234
  • 1 Post By bluebase
  • 2 Post By diamondx
Old   March 30, 2015, 11:37
Default whats wrong with this mesh?(pic attached)
zack
zackufairu is on a distinguished road
Hi people
I am learning ICEM and attempted to do ahmed body meshing tutorial.
What i got was an absolute disaster on top of the car in terms of mesh.
Could you tell me why am i getting this and what i can do to remedy it?
Thank you
zackufairu is offline   Reply With Quote
Old   March 30, 2015, 22:53
Post
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello;
Can you post more pics of your blocking and perhaps the surface mesh as well.
If you want proper help can you upload the blocking file? or if you can't thats okay
zackufairu likes this.
shereez234 is offline   Reply With Quote
Old   March 31, 2015, 10:12
Sebastian Engel
bluebase will become famous soon enough
Hi Zack,
i agree with shereez, more pictures might be needed.
From the first picture alone, i suggest you to check all surfaces and faces, as well as its associations in this area. You might redo the associations as intended.
With regards,
Sebastian
bluebase is offline   Reply With Quote
Old   March 31, 2015, 10:31
Default the mesh file attached
zack
hope this makes it clear
I really am perplexed did the tutorial 2 times now
Old   March 31, 2015, 12:47
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Association problem, 100%. make sure curves are associated with their respective lines. What you can do is cancel all associations. and re-do it. you don't have to generate a new blocking
shereez234 and zackufairu like this.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 31, 2015, 18:05
shereez234's Avatar
M Sereez
Ali is right. Redo the associations. Associate every line to curve and perhaps if that's not good enough associate the face as well. But the geometry of ahmed body is very simple so that just associating every edge to it's curve will be good enough to represent the geometry.
Regards
Shereez
Old   April 1, 2015, 14:41
zack
thank you for your replies
I HAVE found the problem I think and it may not be association.
You see the ahmed car body internally is an empty shell thus the inside of the car was giving a distorted mesh,this was due to no block at its left side(where symmetry condition will be applied)
If the internal body was removed and then premesh regenrated the mesh was much cleaner(normal looking)
Am i correct to remove the mesh from within the body?and with this logic i should ignore the health of the mesh inside the body?
Do let me know
Thank you
Old   April 1, 2015, 15:32
Sebastian Engel
Hi zack,
probably, the inside of the ahmed body is of no interest to you. Hence, it's correct to remove these blocks.
It can be a good idea though to not delete those blocks "permanently" in ICEM. That way you can keep the edge relations between neighboring blocks.
Old   April 2, 2015, 02:41
zack
Status:I am trying to improve the mesh quality now.
Thank you people for your support.
This is kind of wierd that even ansys tutorials dont explain much about improving mesh quality
Right now I am aiming for determinant 3x3x3 quality >0.5 as my benchmark.
please suggest what I can do to improve mesh quality other than increasing the nodes and why the mesh is bad at certain points.(that curved line at rear bottom is particulary persistent)
Old   April 2, 2015, 10:55
Post
shereez234's Avatar
M Sereez
Hello zackufairu
Great that you are able to resolve the previous issue. Quality is really a matter of the solver. If you are taking this model to ANSYS Fluent then Orthogonal quality and skew is the most important with a reasonable aspect ratio I believe.
I have always found that having a quality of 0.1 and above gives accurate results. However the solution is also dependent on number of mesh elements ( mesh independent solution) and solver settings ( Right turbulence models, viscosity value, and relaxation factors). If you will reach there and find some problems do not hesitate to come back and ask.
diamondx likes this.
ahmed body, icem, meshing 3d
udf error srihari FLUENT 1 October 31, 2016 15:18
Multiphase Simulation giving wrong results niazaliahmed STAR-CCM+ 2 June 17, 2011 01:41
tank sloshing - getting wrong pressure enghamed CFX 2 April 26, 2011 23:09
CFX problems with supersonic inlet condition - Inlet values in CFX-Post are wrong jannnesss CFX 5 February 25, 2011 17:24
Axi-symmetric case gives wrong answer pbryant OpenFOAM Bugs 1 February 14, 2011 22:17
