March 14, 2015, 16:59 |
Meshing a pipe with sudden expansion
Farzin
Rep Power: 12 |
I'm trying to generate a structured grid on a pipe with sudden expansion, using ICEM CFD. I tried many methods to do that, though I'm new to ICEM. One of those is to split the block in three part, delete the middle one and associate others individually to pipes with different diameters. Then using O-Grid block split. By doing so I got a bad mesh quality on the expansion area. Another idea was to keep the middle block after the split. It would be a 2D-like block, on the expansion plane. This time I got a little better quality but still not sufficient, on the expansion plane. Here is the mesh quality statistics using the later procedure: Code:
0 -> 0.05 : 301 (1.276%) 0.05 -> 0.1 : 0 (0.000%) 0.1 -> 0.15 : 0 (0.000%) 0.15 -> 0.2 : 0 (0.000%) 0.2 -> 0.25 : 0 (0.000%) 0.25 -> 0.3 : 0 (0.000%) 0.3 -> 0.35 : 0 (0.000%) 0.35 -> 0.4 : 0 (0.000%) 0.4 -> 0.45 : 0 (0.000%) 0.45 -> 0.5 : 0 (0.000%) 0.5 -> 0.55 : 0 (0.000%) 0.55 -> 0.6 : 744 (3.153%) 0.6 -> 0.65 : 246 (1.043%) 0.65 -> 0.7 : 1330 (5.636%) 0.7 -> 0.75 : 2244 (9.510%) 0.75 -> 0.8 : 4188 (17.748%) 0.8 -> 0.85 : 4866 (20.621%) 0.85 -> 0.9 : 3046 (12.908%) 0.9 -> 0.95 : 1768 (7.492%) 0.95 -> 1 : 4864 (20.613%) PIPE_EXPANSION_ICEM-CFD_1.jpg PIPE_EXPANSION_ICEM-CFD_2.jpg Any suggestion would be appreciated, Farzin |
March 16, 2015, 15:54 |
Pascal Balz
Rep Power: 11 |
I'm not sure if I understood you correctly. But here's how I would mesh this geometry: 1. Create ONE block for the whole geometry 2. Do a O-Grid Split on the whole block 3. Do another O-Grid Split on the newly created middle block 4. Split all blocks at the expansion edge 5. delete the four outer blocks at the small cylinder 6. Assign edges to your geometry
Regards, Pascal |
March 16, 2015, 17:40 |
#4 | |
Farzin
Rep Power: 12 |
I did it as you suggested and it ended with a good quality of mesh on the expansion plane. |
March 21, 2015, 15:58 |
Farzin
Rep Power: 12 |
Now I'm trying to do an unstructured mesh on half pipe expansion. I do it in similar way I did pipe expansion.
It gives a good mesh quality, but when I import it in ANSYS CFX, solver says the symmetry planes are not parallel. Actually I found that blocks edges are not exactly on geometry surface [on symmetry plane]. The question is how should I associate blocks edges with curves, which are on symmetry plane? The picture of geo and blocks is attached and edges which are in question are marked. HALF_PIPE_EXPANSION_ICEM-CFD_1.jpg Thanks for any comment |
March 24, 2015, 08:01 |
Farzin
Rep Power: 12 |
I think I've found the fault.
After associating the radial block edges on symmetry plane with nearby curves on the same plane, it seems alright and the CFX Solver works without any interruption. But there is a considerable difference between the later model (half-pipe expansion with symmetry plane) and the whole pipe expansion. The whole pipe result seems to be more accurate and realistic. I extended this conversation to ANSYS CFX sub-forum, in a new thread. http://www.cfd-online.com/Forums/cfx...expansion.html |
December 29, 2017, 14:36 |
Santosh
Rep Power: 9 |
Can you please tell me the step by step procedure for meshing half pipe?
expansion, icem cfd 14.5, meshing 3d, pipe |
[ICEM] ICEM PIPE bend meshing | firavia | ANSYS Meshing & Geometry | 3 | December 23, 2012 10:29 |
[GAMBIT] Meshing 3-D pipe problem | shayan_mv | ANSYS Meshing & Geometry | 7 | August 18, 2012 14:33 |
[ICEM] Meshing a complex pipe network | Industrial_CFD | ANSYS Meshing & Geometry | 0 | January 31, 2012 16:59 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 12, 2012 00:18 |
How to model sudden expansion | kvaswegen | OpenFOAM Running, Solving & CFD | 0 | May 18, 2010 12:32 |
