[ICEM] Blocking strategy for sharp angle junction (Pipe)
Like Tree2Likes
  • 1 Post By kad
  • 1 Post By kad
Old   February 12, 2015, 14:08
Default Blocking strategy for sharp angle junction (Pipe)
Daniel
Daniel_Khazaei will become famous soon enough
Hello guys
I am trying to generate a structure mesh for a 3D pipe with a sharp angle junction which is shown below.
As you can see I have already generated an initial mesh for the geometry. However, the maximum skewness increases by reducing the junction angle.
The blocking can be seen in the attachment. Is there any alternative blocking strategy which can be implemented in order to improve the skewness near the junction?
70 degree junction --->>> Fluent max skewness = 0.67
60 degree junction --->>> Fluent max skewness = 0.74
45 degree junction --->>> Fluent max skewness = 0.83
Regards
Daniel_Khazaei is offline   Reply With Quote
Old   February 13, 2015, 10:04
kad
kad will become famous soon enoughkad will become famous soon enough
You can try to do the ogrid not in one step but in two separate steps. E.g. you do the arc first and then do the rest. You can probably improve the mesh quality by moving vertices in proper positions. There is also a tutorial "Hexa Mesh Generation for an elbow part" which is pretty similar to your problem.
Daniel_Khazaei likes this.
kad is offline   Reply With Quote
Old   February 14, 2015, 00:19
Daniel
Thank you very much kad.
I will try the new blocking strategy and let you know.
Best wishes
Old   February 14, 2015, 16:04
Daniel
Would you please tell me the order of O-grid blocking step by step?
I have tried to get the same blocking as yours but something is clearly wrong with my blocking...
Edit: I think I have manged to get the blocking similar to yours.
I was using blocks selection method to create O-grid blocks instead of face selection.
Old   February 18, 2015, 18:22
Daniel
any help?
Old   February 19, 2015, 10:16
kad
I created ogrid for the arc first. Did you try a blocking method like we worked out in your bifurcation thread?
Old   February 19, 2015, 12:31
Daniel
Not yet, however I was thinking about that too.
I will try to adapt that.
Thank you very much.
[GAMBIT] 3D Two pipe T-shape junction mesh Jing ANSYS Meshing & Geometry 8 April 26, 2013 13:27
[ICEM] Blocking Strategy for Intersecting Tapered Cylinders scribby182 ANSYS Meshing & Geometry 2 December 17, 2012 11:02
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 05:46
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
