[GAMBIT] Draw Secondary Air Inlets on wall
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   December 15, 2014, 17:46
Question Draw Secondary Air Inlets on wall
WTE.Tunisia's Avatar
WTE.Tunisia is on a distinguished road
Greetings everyone
I’m a new comer to the world of CFD.
Currently I’m working on a grate Incinerator.
An over-simplified model is given in the following figure.
By looking at the work done by others, I found that they didn’t include the whole tubes in the secondary Inlet of their models (the over fire air) they just included the end of these tubes.
This allows them, I think, to choose in Fluent the angle at wish the air enters (For automation purposes).
My question is how would you place one of these circles (faces) on the walls (either through GUI or TUI)?
"Anyone can make the simple complicated.
Creativity is making the complicated simple."
WTE.Tunisia is offline   Reply With Quote
Old   December 16, 2014, 03:39
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
do you have the dbs file (Gambit)
Else your geometry isn't quite complicated, and you can build it from scratch
WTE.Tunisia likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   December 16, 2014, 05:53
Default Thank you :)
Thank you for your reply Maxime
Yes, the geometry is simple.
Even with the real model, drawing the walls is easy.
My only problem was with placing the circles on the walls specially since there are dozens of them in the real model. But I think I have a solution.
It's not perfect, but it works. I'll be grateful if you could suggest something simpler.
I included the .dbs and the .jou in the .zip file.
Old   December 16, 2014, 05:55
Default My solution is:
1- I draw a circle (face) with the desired radius
2- I add a point in the middle of the circle and another on the edge (using place a vertex on surface /u-v values/)
3- I add a vertex to the wall on wish I want to place the circle.
4- I use align to transport the circle to the surface
- the vertex in the centre of circle and the vertex on the wall used for translation
- the other two vertexes on the circle will be used for rotation and alignment with two vertexes on walls (the corners for example)
5- I remove the vertexes I added
6- Split the wall with the circle
Old   December 16, 2014, 05:57
Default In text commands(from the .jou file):
face create radius 0.2 xyplane circle
vertex create onface "face.9" uparameter 0 vparameter 0
vertex create onface "face.9" uparameter 0 vparameter -0.19938949
vertex create onface "face.5" uparameter 0 vparameter 0
face align "face.9" translation "vertex.14" "vertex.16" rotation1 "vertex.13" \
"vertex.4" rotation2 "vertex.15" "vertex.10"
vertex delete "vertex.16" "vertex.15" "vertex.14
face split "face.5" connected faces "face.9"
Old   December 16, 2014, 10:24
-mAx-'s Avatar
Maxime Perelli
yep, it is the way to achieve what you want
Now on your geometry you can even afford you to mesh your geometry with full hexa
gambit 2.3.16, geometry generation
Very technical question about solving wall boundary layer ... jlb001 FLUENT 6 December 27, 2014 06:56
material of wall is changed to air! alirezame FLUENT 3 December 13, 2014 12:27
Radiation interface hinca CFX 15 January 26, 2014 18:11
natural convection mehrdadeng CFX 10 February 25, 2011 06:25
secondary air routes Dan Panek Main CFD Forum 3 February 11, 2010 09:56
