[ICEM] Bad quality surface mesh elements at curve
Like Tree1Likes
  • 1 Post By diamondx
Old   December 11, 2014, 11:56
Lightbulb Bad quality surface mesh elements at curve
Benjamin Hogan
benjaminhogan is on a distinguished road
Hi there,
Relatively new to ICEM CFD. I am meshing a streamlined land based vehicle and have encountered a small problem.
I am using a tetra-prism mesh.
For some reason at the trailing edge of the car, where the car's surface meets the symmetry plane, when I use the Octree mesher the surface mesh doesnt seem to stick to the last curve?
I have tried remeshing the bad elements along the curve, but instead it appears to ignore the curve completely?
Any help would be greatly appreciated. Cheers!
Ben
benjaminhogan is offline   Reply With Quote
Old   December 12, 2014, 10:29
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You need to find and use the "Edge Criterion" control. Search the help or CFD-Online for more info.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   December 12, 2014, 11:39
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
read this ->> https://docs.google.com/file/d/0ByIL...BQT3pQMjQ/edit
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 12, 2014, 21:45
Benjamin Hogan
Hi Simon,
Thanks for your reply. I have thoroughly experimented with edge criterion today and whilst decreasing the 'edge criterion' made the problem significantly worse, and increasing the 'edge criterion' improved the situation with a reduced the number of bad cells, it has not solved my problem.
Under closer inspection it turns out that a few cells all around the domain are occasionally not sticking to the curve?
I have attached a few more images that I hope explain the problem a bit more.
Any help or advice would be greatly appreciated - this is really driving me bonkers!
Old   December 12, 2014, 21:48
diamondx's Avatar
Ghazlani M. Ali
For those few cells, you can repair them manually, under the edit mesh tab -> move node -> project node to curve, select those nodes, and VOILA
PSYMN likes this.
Regards,
Ali
Old   December 12, 2014, 21:58
Benjamin Hogan
Hi DiamondX,
Thanks for your reply - very helpful. This would work if I were to perform the action on each of the bad cells.
I am wondering why this problem has started to happen all of a sudden? I have meshed very similar geometries previous to this and have not had the above problem?
Would it be something in general mesh settings? Any thoughts?
Cheers!
Ben
Old   December 12, 2014, 22:01
diamondx's Avatar
Ghazlani M. Ali
Today, it happened to me. I was using the "move node" option, after some saving and re-opening, I didn't have to use it. I really don't know... Make a super zoom on that curve, see if it's really attached to the surface maybe ?!
Regards,
Ali
Old   December 13, 2014, 09:59
Unhappy
Benjamin Hogan
I have tried changing the geometry, refining the mesh, coarsening the mesh, altering the edge criterion and still no luck.
If anyone has any thoughts or suggestions please let me know.
Old   December 13, 2014, 16:03
kad
kad will become famous soon enoughkad will become famous soon enough
Define a node spacing for the red curve via curve mesh setup. Use the maxsize (or smaller) of the smaller surface elements. You can preview the nodespacing by activating it in displaytree (RMB on curves).
kad is offline   Reply With Quote
curve, icem, missing, remesh, surface
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 08:34
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 13:05
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
