[ANSYS Meshing] Error Message stl data loading
Like Tree1Likes
  • 1 Post By AntoniaL
Old   December 11, 2014, 09:15
Default Error Message stl data loading
Antonia Lichtenegger
AntoniaL is on a distinguished road
Hi I am completely new in the field of meshing with ICEM CFD and I am trying to read stl data and generate a mesh. But if I am loading my data the following error message occurs:
An internal error has occured:
bad coordinates
I also tried to load data from a tutorial but the same error is occurring. Maybe someone has an idea what the problem could be? Thank you very much in advance.
javRC likes this.
AntoniaL is offline   Reply With Quote
Old   March 11, 2015, 17:23
Andrea
Andrea1984 is on a distinguished road
Hi Antonia,
I am facing the same error, did you manage to sort this out?
Thanks
Andrea
Andrea1984 is offline   Reply With Quote
Old   April 7, 2015, 11:31
Granada
javRC is on a distinguished road
bad coordinates
Hi , I had the same problem, and I solved it changing the configuration (control panel in my laptop) 'point' and 'coma' for understand decimal and thousands numbers, i. e. using decimal symbol '.' and thousands separation symbol 'coma'. With this type of configuration in setup number I read .txt format with airfoil coordinates in ICEM.
javRC is offline   Reply With Quote
error, meshing, stl
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 08:51
Writing Data for Loading into Tecplot PPPO Main CFD Forum 0 September 29, 2013 03:44
export data at nodes Meenu FLUENT 1 December 30, 2011 02:24
Loading data into graph reg. from external file Julie Polyakh Siemens 0 July 20, 2003 15:27
Loading transient data of moving grid leo Siemens 3 April 9, 2003 02:35
