[ANSYS Meshing] Problems
Like Tree1Likes
  • 1 Post By amin.z
Old   November 11, 2014, 04:51
Default Problems
Ema40 is on a distinguished road
Hi everybody.
When I read the mesh file with Fluent two errors appear:
1)
"Building...
mesh
auto partitioning mesh by Principal Axes
Warning: Partition method "Metis" is not allowed for
autopartitioning for cases with non conformal
interfaces before the interfaces are defined
and intersected, use "Principal Axes" instead.
You may use the "Metis" partition method
after the case is read in and the interfaces
are intersected.,"
2) Note: zone-surface: cannot create surface from sliding interface zone.
Creating empty surface.
Since there is the rotating domain of the water wheel I have created interfaces. Despite these errors, the model reaches convergence, but the calculated torque is wrong.
Anybody can help me? The previous two errors are negligible or not?
Thank you
Ema40 is offline   Reply With Quote
Old   November 11, 2014, 15:49
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey!
about 1st question! I've never encountered this problem before! but maybe rotation axis is reason of problem!
about 2nd question
this isn't an error! only a warning! fluent says this warning because you're using mesh interface! In this case there is no problem...
Goodstuff likes this.
amin.z is offline   Reply With Quote
Old   April 28, 2015, 02:35
Alex Smith
palexsmith is on a distinguished road
I encountered the first error message you got recently. In DesignModeler, I had 3 bodies grouped into a single part. When I broke the 3 bodies into 3 parts, the warning went away.
palexsmith is offline   Reply With Quote
Old   April 28, 2015, 12:58
Thank you everybody very much!
Best regards
Old   January 12, 2022, 10:53
Omkar Mogare
Omkar Mogare is on a distinguished road
I'm getting the first error, but I have only two bodies (one rotating domain and another stationary domain). I am doing 3D analysis of darrieus VAWT. Rotatind domain is completely contained inside the stationary domain (rotating domain does not touch the boundaries of stationary domain).
Omkar Mogare is offline   Reply With Quote
interface, metis, rotating domain, turbine, water wheel
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
[mesh manipulation] Problems with rotational cyclic boundaries TReviol OpenFOAM Meshing & Mesh Conversion 8 July 11, 2014 04:45
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Help required to solve Hydraulic related problems aero CFX 0 October 30, 2006 12:00
