[ANSYS Meshing] How to need to mesh a pipe containing inner fins?
Like Tree1Likes
  • 1 Post By hwet
Old   October 28, 2014, 14:17
Question How to need to mesh a pipe containing inner fins?
Linums
Linums is on a distinguished road
Hello!
Please, I need to mesh a pipe containing inner fins. If anyone can help me I thank you in advance. I want to mesh it with hexahedral me interested in the behavior of the fluid. The part with the fins is in heat flow and bottom isolation. Really will stay eternally grateful if I explain step by step because I do not have much experience in meshing. Attached File image and mesh my geometry.
GREETINGS.
Linums is offline   Reply With Quote
Old   October 28, 2014, 20:57
hwet is on a distinguished road
hex is not necessary, you can just use tets with inflation which can give you good results as well, however if you really want to use hex you can search this forum, some time ago there was a very good post on how to slice a geometry to produce a hex mesh, it was for a U bend pipe but will apply to your geometry as well.
but again if you are new to the software just use tets with inflation
Linums likes this.
hwet is offline   Reply With Quote
Old   November 2, 2014, 11:41
Default Tnanks for answering hwet
Linums
Thanks for answering hwet:
My project I did as you say, but I do not get the desired, make a post where I explain my entire simulation step, if you would be so kind to check out the link and you could give me your opinion:
http://www.cfd-online.com/Forums/ans...-provided.html
regards
fin inner, mesh pipe, meshing 3d
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ANSYS Meshing] block and mesh pipe in pipe Nunuuika ANSYS Meshing & Geometry 3 November 28, 2011 05:26
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[blockMesh] generate a graded pipe mesh. jenright OpenFOAM Meshing & Mesh Conversion 0 August 22, 2009 09:58
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
