July 30, 2014, 14:49 |
How to Ogride a 3D room in ICEM CFD
Mahdi
Rep Power: 13 |
Dear All
I want to mesh a room with a chimney and a window in opposite side of chimney. My objective is 3D meshing using Blocking Technic. now I don't know if I should ogrid the block of room at first and then ogrid it to the faces around the far field? Or it's better to ogrid it at first and associate all edges to the curves and vertices to points of model and after forming the blocks around the model, ogrid all of them to the faces of far field? and I also want to know if I leave the body of 3D far field as Fluid and inlet of chimney and window of room is outlet, should I create another body named fluid to allocate it inside the room? The procedure which I have done is: 1- Creating the geometry and rectangular cube around it as far field. 2- creating the body called fluid inside the far field. 3- creating the block named fluid and associate the edge and vertices to the far field. 4- splitting the block to small blocks around the model. 5- I did ogrid the block around the model and because my model is located on the lower face of far field named "GROUND", I selected the face of ground under the model and did ogrid it. 5- I did associate all edges to curves and etc. Also I spitted small block inside and around the room to small blocks suitable to associate to the windows and chimney to the room surface. Now I don't know how should I focus on the meshes around the room while there is no mesh density on the far field surfaces. Sorry if my novella was not clear. Last edited by metmet; July 31, 2014 at 01:03. Reason: Title's edited |
July 31, 2014, 01:25 |
Mahdi
Rep Power: 13 |
I did edit the title of my thread , but it is not changed so I'm sorry last night I posted this question and I don't know what was wrong with my text!
I have attached my Project's snapshot if it helps. |
July 31, 2014, 13:06 |
#3 | |
As far as ogrid is concerned, you should create ogrid in beginning of your work if you need to fit blocking to geometry. If you want to resolve the boundary layer i.e. fine mesh in vicinity of body, create o-grid in the final stage of your project... |
July 31, 2014, 14:00 |
#4 | |
Mahdi
Rep Power: 13 |
blocking, icem, ogrid |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing Solidworks part into ICEM CFD | MetalSupremacist | FLUENT | 0 | October 8, 2010 17:46 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
