[ICEM] Merging Blocks
Like Tree8Likes
  • 1 Post By juniorjuice
  • 5 Post By kad
  • 2 Post By Far
Old   July 2, 2014, 11:47
Default Merging Blocks
Jimmy Crawford
juniorjuice is on a distinguished road
Im working on creating a mesh for a flow through a short strut. We basically have air issuing from one plenum to another through a short duct, and so the blocking is relatively straightforward. In terms of an overall strategy, I have created what Im calling a C-grid (an O-grid that follows the solid wall surfaces), so that we can have some structured refinement of the boundary layer. My problem is that I wind up creating an extra block that I dont want. I have attached a 2D sketch of the problem (my actual geometry is 3D, but if I can fix it in 2D the change should be straightforward). The extra block that I am referring to is the bottom hatched one on the top drawing - I want to be able to merge it with the block above, and then basically take the face mesh that I create on edges A, B, and C, and project them onto D. But that would involve creating a block with more than 4 edges. Is what Im trying to do possible?
Thanks
Jimmy
lukasf likes this.
juniorjuice is offline   Reply With Quote
Old   July 3, 2014, 09:08
kad
kad will become famous soon enoughkad will become famous soon enough
Start with the blocking structure shown in attachment 1. When splitting the initial block do not use the option "all visible" but "selected" for blocks. Then create quarter ogrids at the lower corners and delete the inner ogrid blocks (attachment 2 & 3). Move the vertices in place and set your mesh parameters and you are done. You might use linked bunching for the block with six vertices.
Far, diamondx, bluebase and 2 others like this.
kad is offline   Reply With Quote
Old   July 11, 2014, 20:38
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
@kad . You are doing magic with quarter ogrid
kad and lukasf like this.
Far is offline   Reply With Quote
Old   August 4, 2019, 08:24
Lukas Fischer
lukasf is on a distinguished road
I would like to do this in 3D. 2D is working.
Any suggestions?
lukasf is offline   Reply With Quote
Old   August 4, 2019, 08:32
Lukas Fischer
The lower one of the centered blocks needs to have a 3D Ogrid.
It would be OK if the top one also has an Ogrid.
Old   August 4, 2019, 08:34
Lukas Fischer
Please see my attachment.
File Type: jpg Screenshot from 2019-08-04 13-29-09.jpg (73.7 KB, 49 views)
Old   August 4, 2019, 14:16
Far
Sijal
Yes you can
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 10:04
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
[ICEM] merging meshs from different types of blocks kpax ANSYS Meshing & Geometry 11 November 13, 2012 10:31
Merging the blocks in ICEM saisanthoshm88 ANSYS Meshing & Geometry 1 December 27, 2010 11:14
