[ICEM] NREL Phase VI Wind Turbine
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By Far
Old   June 28, 2014, 18:10
Default NREL Phase VI Wind Turbine
vatsal
vatsal1610 is on a distinguished road
Hello guys,
I am performing simulations on the NREL wind turbine (radius:5m) in Fluent and I have generated mesh in ICEM.
My first problem is I am not able to generate mesh on the trailing edge of the blade, thickness is defined at trailing edge and surface element is breaking. Moreover, while the prism layer are not generated on trailing edge of the blade instead it ignores the trailing edge. Additionally, using interface and need some tips for mesh generating.
vatsal1610 is offline   Reply With Quote
Old   July 1, 2014, 13:39
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you can use surface blocking to get mesh on surface.
Use delaunay method with surface mesh alraedy generated.
Far is offline   Reply With Quote
Old   July 19, 2014, 12:00
vatsal
Thank you Far,
I have defined the dimensions and quantities in the global mesh setup and instead of generating octree surface and volume mesh I have used 2D surface blocking to generate surface mesh. By doing this I have achieved a good quality of surface mesh and there is no destruction on the surface mesh (trailing edge).
It really works good and fast.
Old   July 19, 2014, 12:09
Far
Sijal
Originally Posted by vatsal1610 View Post
Thank you Far,
Yeah, we did simulations on NREL IV with this method and it really worked
But you know you cannot find this method in help
Octree, shell meshing etc with edge criteria, auto blocking etc but that didn't work ...
Best of luck
zeeshu likes this.
Old   July 19, 2014, 14:00
Far
Sijal
Thank you Far,
Use these options in surface blocking
1. If you want all tri : surface blocking > free
2. If you want mostly quad : surface blocking > mostly mapped
FJSJ likes this.
icem, nrel, prism layers, trailing edge resolution, unstructured grid
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 18:18
Simulation of NREL UAE Phase VI turbine aqstax FLUENT 63 June 25, 2014 11:28
BEM Analysis of NREL phase VI turbine er_ijaz Main CFD Forum 11 April 17, 2013 09:04
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 11:50
FSI - Wind Turbine AUN CFX 13 August 29, 2012 17:44
